Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Race Tech
Reload this Page launching on nitto DR's
Reply
(#1 (permalink))
Old
94Five0's Avatar
Loose Colon
launching on nitto DR's - 11-07-03, 08:39 PM
jus aquired some nitto 555r's for my 94 GT..how do i launch w/them? dry burnout or waterbox?.. . also how much air do i need to run in em? and do i need to do anything on the virgin run like heat em up really good? I usually power break it to 1400 an nail it.. any tips?
i've only run on street tires before so i'm tryin to do this right.
as for my drivetrain setup, i'm bone stock w/ 3:73's, auto trannie, an steeda springs..
thanx stangers
(#2 (permalink))
Old
blackholehunter's Avatar
Banned
11-08-03, 06:00 AM
thanx stangers
They are not nitto's but, with my bfg's I drop the air pressure down to 12psi. You probably won't have to take them down to 12psi but, I'm just saying you can if necessary. Also, do a decent burnout everytime with them. Look for smoke in your rear views. On the first pass with them I'd burn roast the "F" out of them. I use a wet burnout like slicks. Just roll through do a quick blip of the throttle when in the water to get the tire coated and roll forward and do you burnout. Good luck!
(#3 (permalink))
Old
11-08-03, 05:36 PM
Heres what i do on my nittos. Drop them to 14psi. Pull my back tires into the waterbox give them a quick spin to get them wet. Pull up a few feet and spin the **** out of them till they smoke real good. They hook great for me.
(#4 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-11-03, 01:09 PM
If you are basically stock, the burnout isn't that critical for you. Just spin them enough to clean them off. Make sure to go through the water so your posi doesnt make 1 tire spin in the burnout.
1993 Mustang LX Hatch
Stock engine/ 1.72 rockers/ Hedman shorty headers/ 3 chambered flowmasters/ 4.10 gears/ Moser C-clip eliminators, spool and 33 spline axles/ C6 tranny/ Art Carr 9" converter/ Over 1,950 passes on car and motor/ 107,000 miles before taking it off the road/ 3,470 pounds/ MT ET Streets 11.5X26X16/ Strange 10 way adjustable shocks and struts/ Southside lower and UPR double adjustable upper control arms
Best ET: 13.73 @ 97.8 MPH
Best 60': 1.813
(#5 (permalink))
Old
AXIStang's Avatar
11-11-03, 01:16 PM
I do the same thing 14 psi, back in & spin. Pull out and burnout. Drop it at 3k. In my auto I just do a dry burnout to clean them and dont even drop the air.
(#6 (permalink))
Old
94Five0's Avatar
Loose Colon
11-12-03, 03:32 PM
thanx for the replies. i ran a new best..(if ya call it that) sunday.
but i know i didn't heat em up enough..started goin sideways on me in the box..
i'll need to break em in i think. runnin about 15lbs. but i am happy with em compared to my street tires, like day a n night..
(#7 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-12-03, 03:35 PM
Going sideways in the box doesn't have anything to do with your burnout. It's usually because of bad water placement and/or amount of water in the box. I think you will be very surprised by the results if you run a lot more pressure. As far as wear and top end stability. With radials, you really don't need very low air pressure.
Best 60': 1.813
(#8 (permalink))
Old
11-12-03, 09:40 PM
The first time i went to the track i was on new drag radials had like 50 miles on them. The first time i ever went to the track i pulled a 1.95 60 foot time. Try the method i posted above it worked well for me and i didnt even launch hard.
(#9 (permalink))
Old
ciwsking's Avatar
11-13-03, 08:54 AM
I agree with stangin it. You got to heat em up real good. My best 60' w/ 555R's was 1.88. I can't get consistent with them so i'm getting ET streets next.
(#10 (permalink))
Old
90sting's Avatar
Official Member
11-13-03, 09:05 PM
HOW GOOD IS THE ET STREET over the 555r's ?
iam thinking about getting the et streets or sould i get
the slicks ?
(#11 (permalink))
Old
11-15-03, 12:55 PM
Nittos have to be heated. I put my psi around 16# and do a good 6-8 second burnout and quickly stage. I normally cut low 1.8's with a best of 1.74 on 17" nittos. -Mark
98' red cobra(N/A) Stock longblock
11.79@114.64 (1.62 60ft)
(#12 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-15-03, 01:40 PM
ET streets by far. Unless you have MAJOR HP, you will not need to go with the slicks. They have lasted me 190 runs with a pretty smoke burnout and you can still drive them on the street and the cops cannot hassle you.
Best 60': 1.813
(#13 (permalink))
Old
AXIStang's Avatar
11-15-03, 03:13 PM
I have a MM&FF comparison around here somewhere. The ET street cut a 1.60 and the Nitto Drag Radial cut a 1.63 (the Nitto was .03 off). They were saying the Nittos drive much better in the rain. I havent had a problem with them in the rain just dont drive stupid and they are awesome.
(#14 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-15-03, 03:54 PM
haha, if you are talking rain now, forget the ET streets. You will be dead or somebody else will. They have grooves in them to make them legal, but they DO NOT help at all.
Best 60': 1.813
(#15 (permalink))
Old
ET Streets - 11-19-03, 11:32 AM
Quote:
What to ya'll recommend for best street riding taking wet streets in consideration and something that will grip at the track?
(#16 (permalink))
Old
RyanSG's Avatar
11-26-03, 11:16 PM
stupid question but where do you guys buy your tires at?
(#17 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-26-03, 11:42 PM
BDealer, if there were such a thing, that person that invented them would be a multi-millionaire. BFGs are by far better than ET streets for rain. But, that's pretty much understood. No tread, water, no traction.
Best 60': 1.813
(#18 (permalink))
Old
JJFIVEOH's Avatar
Official Member
11-26-03, 11:44 PM
Quote:
I buy my tires from a race driver down here so it won't help you. If you are looking for MT, call them up and they can tell you the closest dealer. I got my 26X11.5X16 for $350 mounted and balanced. Small price to pay if you want to order them and have them shipped. Ever see the shipping prices?
(#19 (permalink))
Old
RyanSG's Avatar
11-26-03, 11:47 PM
i'm looking for something relativly streetable if there is such a thing, since i use my car everyday 4 school, work etc.. the michelin pilots arent cuttin it, they work great if i don't want to hit the gas other wise there smoking through 3rd. Fun to watch but thats about it.
(#20 (permalink))
Old
12-14-03, 12:54 PM
Quote:
I am a little confused about what is seemingly being said in this post and a couple others in this thread. When I was learning how to do burnouts at the track I was consistently told to drive thru the waterbox slowly just to wet the tires and NOT spin the tires in the box. The reason being that as you spin the tires in the box the water splashes up onto the wheel well and drips back down as you are sitting at the stageing line. Thus giving you wet tires or at least wet spots on your tires when you are trying to launch hard.
that seems to make sense to me.
2004 Dark Shadow Gray GT - Bone stock for now
1991 Black/Black LX notch 331 Jim Kuntz Stroker with Lentech AOD
(#21 (permalink))
Old
12-15-03, 08:05 PM
just a FYI in Mid Apil Mickey Thompson will be coming out with a 275/60/15 and 275/40/17 drag radials...
Life begins at 15lbs of boost
94 GT Coupe 5spd
DSS 306, Vortech S-trim, Edelbrock heads and some other stuff
(#22 (permalink))
Old
Dan_Soprano's Avatar
Official Member
12-16-03, 01:40 PM
Discounttiredirect
they have great prices on Nittos and free shipping!!
Former 4.6 /SVT/ Northeast Moderator
07 F-150 FX2, 5.4 Triton Supercrew
2004 Redfire Cobra Coupe-Sold-RIP
Street Stangs of Maine
