This THREAD brought to you by... |
Official Member
EGR delete -
11-08-03, 09:23 PM
on my 87 t/c motor i was wandering if ne body else block this pos off and tossed it?
Windsor II
11-10-03, 06:00 AM
Quote:
Usually people only bother blocking it off if they have rotated the upper intake. Even though it has been pointed out that the EGR hole on these is so small that it has little effect even as an EGR, and is only there to keep the emissions people happy.
01-13-04, 08:59 PM
Does anything else need to be done? If I am not mistaken then that little box on the right strut tower with the red and green vacuum lines going it has something to do with the EGR? Can I just unplug that, plug the vacuum lines at the Vacuum Tree, put a plate over the EGR hole and a plu in the manifold? Thanks....
1987 mustang vert 2.3t
87 TC engine/computer, front mounted IC, CAI, 2 1/2" Flowmaster exhaust, Hydraulic Roller cam HR276, large valve 1.89 Int. 1.59 Ex. conversion, Gillis valve w/ boost solenoid, T3 turbo, 1 1/2 lowered, GT front and rear swaybars, '92 Integra bucket Seats, brand new top (pain in the ass to install).
01-13-04, 09:51 PM
I have blocked it off but not tossed it. When I put my Ranger header on I had to weld shut the EGR bung because the tubes did not line up for the return. I had unplugged the vacuum line that opens the EGR system, but this caused the Check Engine light to come on, so I made a plate to block the system and plugged the vacuum line back in. The reason for keeping the EGR system there is for a visual check for the emissions test.
1992 2.3 LX Bimini Blue
My website
Mods:
Engine:
Removed air silencer and removed bottom of air box
K&N air filter
Removed air resonator replaced with steel tube
Single 40 series flowmaster
Ranger Header
86 TC motor to be cont.
T-5 swap done
Suspension:
HPM Strut Tower Brace
1 5/16" Front Sway Bar
Poly End Links and Sway Bar Bushings
1" Steeda Rear Sway Bar
Custom Full Length Subframes
01-13-04, 10:42 PM
why?
Type O Danzigative the Dark Lord of All Dark Things in the Dark of Darkness
01-14-04, 12:03 AM
Blocking and keeping it passes visual inspections.
President, Official Stinger Club Official Stinger Club Member #1
01-14-04, 07:02 AM
toss it.
01-14-04, 07:18 AM
I've tossed it on a 93 n/a, an 88 n/a, and now my 88 turbo engine. No problems have resulted from it. I like it simply because there's less stuff in the way when I go to try to work on my engine.
03 VW Jetta 1.9l TDI - 52mpg daily driver!
88 351w Twin Turbo Mustang - Twin HE351 Holsets, PowerStroke FMIC, aluminum heads, solid roller valve train, hi-po C4, 10pt cage, Megasquirt
99 F-250 SD Power Stroke Diesel - 4x4, 2" lift, 35's, Detroit Locker, 4" straight-piped exhaust, Wicked Wheel compressor, TS Performance Chip
ASE Certified - A1, A4, A5, A7
01-14-04, 09:26 PM
What does it gain you by blocking the EGR?
01-14-04, 10:59 PM
Keep it simple. Just take the EGR pipe off, and plug the 2 ends with plumbing plugs. Simple, cheap, and easy.
1986 Mustang SVO
2.3 Turbo, 225 RWHP, 258 RWTQ
why can't you turn and face me
you ****ing dissapoint me
Official Member
01-15-04, 09:20 AM
Yea the car runs great w/o egr
glad i tossed that pos
01-17-04, 10:28 PM
Anyone disagree and say that it DOES help? My 79 Pinto has a 2.3 EFI system from a '87 Mustang, without EGR. (Valve present, but blocked off) and I was thinking of putting one on. The car has an annoying hesistation on acceleration sometimes, thought maybe the computer was being goofy since the air/fuel system wasn't receiving the exhaust gas that it was expecting.
Thanks!
Jeff
79 EFI Pinto
78 Mustang II 302
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
