| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
Most boost I can get out of a PS1C? -
11-12-03, 11:05 PM
Hey Guys, Im looking at forging this 2v I may be getting. It has a P1SC on it, pulley'd for 12 lbs. Right now he has it running very rich, as to save the engine.
I plan on forging it with this kit I found thats relatively inexpensive, and then after I forge it, I have the fuel system to support almost 500 rwhp.. so I figure, I may as well crank up the boost and dyno tune!
Whats the maximum boost I can see through this thing? I may get a Fox Lake or Bullitt Intake as well..
Im hoping I can pulley it for 16 or so PSI.
-Ryan
11-13-03, 12:55 AM
I pushed 15 out of mine when i had it.. it will support upwards of 800 hp so you have a ways to go.
11-13-03, 01:17 AM
15? What size pulley did you run?
Sweetttt
Right now, with a rich ( 10.2:1 the entire way ) tune etc etc...
it is running 380 rwhp 390 rwtq.
Car has a ton in it.. my plan is to forge it, bullitt intake, shove 3 more PSI into it ( power pipe + next pulley down ) and see how my fuel system holds up from there... with a steady 11.0:1 a/f ratio...
-Ryan
11-13-03, 01:59 AM
oh man i want to say it was a 3.35 pulley. what ever one ATI sent me when i told them I wanted 14lbs. 10.2:1.. wow that is crazy rich.. you can do some leaning out and probably gain a ton.. Although I wouldn't go much higher on a stock 2v either
11-13-03, 05:07 AM
What about just going with the D-1? You will have all the boost you could ever need. Just a thought. The D-1SC is in my future.
2000 GT built by T&J Performance
Administrator
11-13-03, 09:42 AM
Quote:
I think he's asking because it already has a P1SC on it.
-Smoky
11-13-03, 09:54 AM
Is there a power pipe that is currently being made for this blower that will fit a 2000 GT or do have to custom fabricate one. Also, If I am running 12.5 lb of boost how much more can I get out of a power pipe. Will I need to retune my computer?
Official Member
11-13-03, 10:22 AM
Quote:
-Smoky
Ditto.. ATI wants 1200 bucks to upgrade from the P1SC to the D1SC. I'm also going through this same delima!
11-13-03, 02:24 PM
Quote:
I got mine upgraded for $900 . 1200??
peace
03 Cobra Silver Vert
SCT tune by Mike Dez Racing 571.2rwhp/522rwtq
Whipple 2.3 @ 17psi
Billetflow 100mm idler
K&N FIPK
Borla Stingers
"Look Ma, I still got the stock manifold and stock midpipe!"
11-13-03, 03:01 PM
Yes, there is a powerpipe that will fit a 2000 GT and a P1SC...
It will apparently give 2-3 lbs of boost...
the car is pullied for 12 psi... so I was hoping i could pulley down, and throw the power pipe on there.. I know when I get the bullitt or fox lake intake, I'll lose 2 psi or so...
Im getting the internals forged.
As for the upgrade.. Im working on a budget... I plan on getting the modular depot chip burning software, selling the autologic chip currently in the car, buying a forged kit from a buddy for cheap, and getting the work done. Im hoping to get all this done for $3000 or so out of my pocket.
-Ryan
11-13-03, 07:13 PM
[quote] [I got mine upgraded for $900 . 1200??
/QUOTE]
I paid $1,080 for my P-1 to D-1 Upgrade.
John
Black 99 Cobra Coupe(#3456/4040) with 3.73 gears
Forged and Bored 281 with a D-1SC Procharger (14Lbs)
Autologic & SCT Big Air MAF (2800)
Sieman Deka 55lbrs and 2003 Tank/Pumps & KB BAP
Morpheus Power Pipe
Hooker LTs, Bassani X pipe (cats), & GT Magnaflows(cats)
Solid Axle - 31 Mosers & 31 Eaton Posi
T56 Tranny
Nitto N1 275s on front and BFG Drags 315s on rear
SAE : RWHP=576, RWTQ=471
11-19-03, 01:01 AM
okay, Im gonna email reichard.. see if it works...
the car has the reichard 12 lb pulley on it.. Im hoping he can make one that is a bit smaller... unless Im already maxxed out.. and if it is.. ****!
PowerPipe will be done tho.. so.. 2 lbs there
-Ryan
11-19-03, 01:12 AM
have you called ATI and ask them what size you need? I don't see any reason to upgrade the P1 unless your pushing in the 700 hp range then i may for ease on the blower and lower intake temps but the P1 per ATI has a max boost level of 30psi, 1200 cfms or 825 hp not to mention a max impeller speed of 62,000 rpms. You have some room to go here. 16-18 lbs shoudn't be an issue, that is if you can keep the belt from slipping. You are not maxed out and if you can't get more boost out of smaller pulleys then my guess is your slipping and need to upgrade to an 8 rib set up. I'd call ATI they will tell you exactly what pulley you need for what boost/hp level on your car.. plus they will tell you how many rpms you are spinning the blower. Also what intercooler are you running.. if you only have a 2 core then that may be a restriction as well if your measuring manifold pressure since it's only good for around 500 hp . 913-338-2886
11-20-03, 03:06 AM
Quote:
Running Mac Long Tubes, and have the 3 core intercooler.
I didnt think about upgrading to the 8 rib pulley.
Thanks!
-Ryan
GoldMember
11-21-03, 02:08 PM
Thanks!
-Ryan
Careful...you're already at 12psi, and you're going to do a power pipe AND pulley down?!? That's going to put you near 15psi. I think your stock block is gonna go bye-bye.
But good luck, I hope it works for you!
SOLD 08/30/2003 :
2001 GT Premium 5spd silver/black
429rwhp / 404rwtq SAE Corrected @ 11psi
Novi 2000 "Mongoose" Kit with Adaptive Tune from T&J Performance
HP Billet Blower Cams
42lb injectors & 80mm Pro-M MAF
Reichard Racing 3.6" Ultragrip Pulley
Bassani X-pipe w/cats & Catback
FRPP 3.73 gears
SPEC Stage II Clutch
Pro3i LCAs / Steeda Sport Springs / Steeda Adj. Rear Sway Bar
Kenny Brown Super Subframes
CDC "Shaker" hood kit
Hurst Line Lock
Lots of misc. bits
01-25-04, 06:49 PM
He's just dreaming about the future after the rebuild and forging, man.
I would say that 10:1 is way too rich even for a stock motor. You should be safe at 11.5-12:1. If possible have the timing curve altered to reduce the top end charge and thus keep the peak power at around 400rwhp. As long as you stay 12:1 or so and not too aggressive on timing you will be fine.
'01 Cobra 'Vert #2650 of 3384. Silver and Black.
Procharger P1SC and 3-Core IC, 3.2 in pulley(12psi), '03 Cobra tank and pumps, 80mm L-MAF, 42 lbers, Morpheus Velocity Tube, Spintech Catted-X and Catback, JMS 4-bank Chip.
455rwhp/441rwtq
Oct 2003 MMP -- 12.527@114.88, 2.034 60 ft.
Bama Mafia Where V6 owner's don't act like a$$holes.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
