Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Reload this Page Help with my Punch 15"
Reply
(#1 (permalink))
Old
JOHNP's Avatar
Help with my Punch 15" - 11-13-03, 06:29 PM
Hey everyone, I was wondering if anyone has a suggestion for waht type of box for a 15 inch punch sub? I currently have it in a ported box in my 96GT, but was wondering if anyone has any suggestions for a better box that will still fit under my Mach460 rear deck. Any suggestions or pictures of s single 15 in the trunk????
(#2 (permalink))
Old
88GTtom's Avatar
Official Member
11-15-03, 08:38 AM
your sub should of came with dimentions on the best setup and box size to run it in, if not find it out and have a custom box built for it. the box is what makes the sub sound its best later tom
07 satin silver gt 331 gears
current mods: whipple HO gen 2 kit, 8lb pulley seeing 9 lbs, thump_rrr tensioner, cobalt wideband and boost gauges. custom tuned by tillman speed-472hp,447tq
88 gt SOLD!!
(#3 (permalink))
Old
Banned
11-16-03, 06:55 PM
How did you fit a 15 in your trunk? Or do you have a hatch back? If you have the trunk of a 94 -98 can you post pics?
(#4 (permalink))
Old
JOHNP's Avatar
11-20-03, 05:04 PM
Quote:
No pics right now. The trunk is completely bare at this moment while my suspension is being installed and some other stuff. Maybe this weekend I will get everything donw and back in, I will post some pics then.
(#5 (permalink))
Old
JOHNP's Avatar
12-20-03, 04:39 PM
Here are some pictures to give you an idea of what I have now. Looking for a better design for a box.
here it is as it normally sits:
(#6 (permalink))
Old
JOHNP's Avatar
12-20-03, 04:40 PM
Here is it pulled out:
(#7 (permalink))
Old
damacman's Avatar
Official Member
12-24-03, 02:46 PM
Facing the sub up isn't nearly as effective as boundary loading the woofer. This is why you see alots of rear-firing subs in sedans. In the case of your 'stang, this isn't possible with a 15 inch woofer. However, you can get even better results by facing both the sub and the port at the floor. Boundary loading the sub and port to the floor of the vehicle will result in a significant gain in output. In your case, this could be pretty simple if there is any clearance between your existing box and deck now as you could simply turn the box over and wallah. You'll need a minimum of an inch and a half between the woofer and the floor. This could be done easily enough by sliding some 2x4 spacers under each end of the enclosure. If you like the sound, then permanantly attach them to the box.
Try it and post your results.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Post pictures of II's with 15" and 16" wheels 1badII MII Discussion 18 12-05-03 02:00 PM
