Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Power Adders
Reload this Page What size injectors
Notices
Reply
(#1 (permalink))
Old
What size injectors - 11-19-03, 07:22 PM
i added a vortech t trim kit to my other wise stock lx 5.0 AOD(flow masters). What size injectors and MAF would be good. I put too big injectors on my G.T & it caused a lope @ idle.My tech guy says 24#, i think it should be more like 36#. Please help quick so i can by them . I also am getting a throttle body. the kit came with a inline fuel pump.
(#2 (permalink))
Old
Psychdaddy's Avatar
11-20-03, 10:54 PM
Personally, I would go with 42 #ers and a 75mm, 77mm or 80mm MAF with a supercharged calibration. You run anything less than 36 #ers and you will most likely need an FMU. But before we go any further, hopefully you have upgraded your exhaust system? If not, I would highly recommend doing so before you go romping on it with any serious amounts of boost.
(#3 (permalink))
Old
Tat98Cobra's Avatar
11-22-03, 02:34 PM
Quote:
42s minimum. You cant change injectors without changing the calibration in your MAF - so dont even try to. If your car ran bad with 36's you probably didnt touch your MAF correct? When Injectors and MAF's are calibrated correctly - car will run pretty awesome without even a chip
peace
03 Cobra Silver Vert
SCT tune by Mike Dez Racing 571.2rwhp/522rwtq
Whipple 2.3 @ 17psi
Billetflow 100mm idler
K&N FIPK
Borla Stingers
"Look Ma, I still got the stock manifold and stock midpipe!"
(#4 (permalink))
Old
Official Member
12-08-03, 12:04 AM
Just repeating what's been said, 42#ers and 80mm MAF.
(#5 (permalink))
Old
droptop93's Avatar
12-08-03, 04:17 PM
I would say 42's are too big for a stock 5.0 with a vortech on it. They might cause you more problems than needed, and I would probably go with some 36's and a 75-80mm MAF (depending on if you plan to run more boost and bigger injectors down the road).
Put it this way, I was planning on running 42lbers on a twin turbo H/C/I 302 with around 8 psi of boost.
I don't think the stock 5.0 will flow enough to need em...but thats just my .02
1993 Mystic Pearl Black GT Conv.
-Modifcations are listed HERE-
Best ET motor: 12.98 at 105 MPH (1.8 60')
Best ET spray: 12.99 at 110 MPH (2.0 60', 75 shot, street tires)
Best ET turbo: 12.89 at 130 MPH (2.5 60', 14psi)
(#6 (permalink))
Old
Psychdaddy's Avatar
12-09-03, 11:17 AM
This could be true. 36's would probably be perfect, but if you're going to spend the money for new 36's you might as well get the 42's and make them work. He is already spending the money on a big MAF and has purchased a nice blower. There isn't a single person I know who stops modding after a supercharger & injector investment. Matter of fact, he can't stop modding after these few additions because if he hasn't upgraded is fuel system he most likely will lean it. Or he will blow a gasket due to the minimal exhaust upgrade. I guess the bottom line is if he has the money, he can afford to custom-tailor as he upgrades, but if he is like me he should probably plan for the next improvement.
(#7 (permalink))
Old
droptop93's Avatar
12-09-03, 03:05 PM
Quote:
All depends on how far he is wanting to go. If more mods are planned down the road (as in heads, higher flowing intake manifold, etc) then you might want to get the 42's and deal with the problems till you get your next upgrade.
Otherwise, I would say get the 36's, set the fuel pressure, and be done with it. The 36's would still leave you room to grow for some small mods (exhaust, power pipe, etc) but would probably run out of juice if you put on some heads and a bigger cam.
Figure out where you want to go with it, and decide from that. I think you have plenty of input to make your decision.
(#8 (permalink))
Old
jonnyk's Avatar
12-09-03, 05:16 PM
I think 36 and 42# injectors are left to H/C/I/power adder cars. Unless you are running crazy boost, that T-trim/stock motor combo won't be making enough power to warrant anything more than 30# injectors. You don't want to overinject because you'll have to turn fuel pressure too far down to get the tune right, and injectors have greatly reduced capacity to atomize fuel when the pressure drops too low.
Mods Pics
13.18 @ 106.09 mph
Novi 2000 waiting for 2004.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
please help..what do i need for injectors and maf size? tvmango 5.0 Tech 7 12-08-03 12:08 AM
