Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Race Tech
Reload this Page Setting up fox susp. for straight line
Notices
Reply
(#1 (permalink))
Old
Official Member
Setting up fox susp. for straight line - 11-30-03, 04:37 PM
What is a great drag setup for a fox, like the brand of parts you would use from a kmember, a arms, coilovers to the upper/lower control arms?
(#2 (permalink))
Old
Rick 91GT's Avatar
Officially Addicted
12-08-03, 05:05 AM
Quote:
I have the UPR front kit and really like it, everything went together smooth and square, the PA Racing kit is also very, very nice and offers a little more clearance. Depending on the weight of the car you'll end up with a 130-175 14" spring. I'd use a good adj strut the Strange pieces are nice for the price.
As far as rear susension goes, you have many choices, fpr uppers and lowers the UPR, Wolfe Racecraft, Metco's, or Steeda drag arms are hard to beat. You can go with a Poly bushing or Spherical bearing in the rear end housing. You'll also want some adj shocks and a Anti Roll bar, if your interested I have a brand new UPR unit for sale, retails for $329 I'm asking $275 shipped OBO, no reasonable offer refused.
Rick91GT@suscom.net
www.metco-inc.com
www.paracing.net
www.steeda.com
www.uprproducts.com
Check out RNH Performance Performance Engines and Custom Fabrication.
From Mild to Wild we can build what you want, when you want it.
(#3 (permalink))
Old
12-15-03, 08:09 PM
my setup:
PA Tubular K-member w/ Tubular A-arms
Lakewood 90/10 struts
Lakewood 50/50 shocks
Chassis Engineering LCA's
Hotchkis Adjustable Uppers
UPR Airbag
4cyl springs front/rear
been 1.44 60' on 28x10.5 slick spinning a little bit.
Life begins at 15lbs of boost
94 GT Coupe 5spd
DSS 306, Vortech S-trim, Edelbrock heads and some other stuff
(#4 (permalink))
Old
EMW150's Avatar
12-17-03, 03:44 AM
I like the QA-1 stuff although it's a bit pricey compared to some of the other brands. I use Lakewood 90/10s up front, Eibach drag springs, and a QA-1 K-member with stock control arms. A coil over setup for the front is definately the way to go if you can swing the extra money. You can cut alot of weight out going with tubular control arms. In the rear I run Pro 3i lowers which are ok and adjustable uppers. The big deal in the rear is the Anti-roll bar. That's hands down the best suspension mod I made. Dropped my 60s from high 1.6s to mid 1.5s. I run the UPR just like Ricki has for sale. As far as shocks, I currently have the Strange adjustables in the rear which aren't the greatest. I didn't realize when I bought them but they're only adjustable on the rebound and not compression. I want to get a set of the QA-1s when I can swing it.
Eric
'84 GT - 331ci w/TEA ported Canfields, Anderson N-111 hydro roller, AED Modified Holley, Vic Jr., Liberty Pro-shifted TKO
10.92@124.8 (N/A, Pump gas, ET Streets,1.576 60')
433 RWHP / 379 RWTQ (N/A, Pump gas)
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
