| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
99+ engine swap to 96 v6? -
12-02-03, 12:27 AM
Has anyone ever done an engine swap from the 99+ mustang v6 to the earlier ones? and if so what was necessary? and lastly how difficult was it?. any inputs would be very much appreciated. My friend needs to swap his out for a new one since he grenaded his motor on thursday and was hoping to get the 99+ engine. thanks again in advance.
Official Member
12-02-03, 07:56 AM
as far as i know, the only real differences in the motors are the intake and the heads. so you should be able to drop it in, connect the wiring and switch to a newer stang computer  it doesn't seem, like it would be too hard, but i've also never done it.
how about swapping to a 4.6? would probably cost just a little more for a lot more performance and upgradability down the road.
93 no option Notch
306 8.5:1, TW heads, Systemax intake, custom blower cam, 80mm Accufab t-b, 75mm Pro-M maf, BBK cai, pullies, 30# inj, 255 lph pump, MSD 6BTM, 3 row alum rad, 1 3/4 lt's, 2 1/2 o/r Pro-Chamber, Flowmaster 40's, subframes, Eibach drag kit w/air bag, lca's, MM c/c plates, Spec stage 2, Steeda clutch quad and firewall adj., 3.73's, 5spd, tuned by LaFerriere Racing
3150 w/me
best to date - 13.78@106.8 on 225s cutting sweet 2.37 60's
CARRY A FIRE EXTINGUISHER
12-02-03, 04:11 PM
thanks mike93lx, but he likes the idea of the underdog.
Anyone else? i see you guys are looking!!
Official Member
12-02-03, 04:47 PM
That is THE hardest "mod" to do. almost everything needs to be changed: the fuel lines and tranny just to name a few.
97ekcoupeb18c1
'02 True Blue Mustang Coupe SOLD
Steeda Tri-Ax Shifter T-5FOR SALE
it came to $4.56 and i got $0.44 change from a 5, man, they must be dumb
12-02-03, 07:54 PM
few implies more then 3, not just two, you need to slow down when your are posting...
04 GMC Sierra
-97 v6 mustang **sold**
-15.168 @ 90.73 mph
-Teh Modz: JVC KD-S590 sytem, Bazooka Speakers, 35% platinum Tint, p&p upper and lower, 3:73's & t-lok, Shorty Headers, Mac CAI, UnderDrive Pullies, Mac Short Shifter, Mac O/R X, Ravins
Quote:
Originally Posted by Kilgore Trout
Damn... Seriously? Owned by 97V6silver??? Man, I am slipping. That sux. Are you sure? Damn...
12-02-03, 07:55 PM
"look at me i'm going to pick on some one because i'm too stupid to understand what their talking about"
04 GMC Sierra
-15.168 @ 90.73 mph
Official Member
12-03-03, 01:52 AM
Quote:
i was just correcting him dumb****.
12-03-03, 11:16 AM
The entire fuel system needs to be changed to returnless style. Others have done swaps similar to this one, so check this forum and others with the search function.
12-03-03, 05:57 PM
no you got me all wrong the sarcasms from another topic on here, where i speeled a few things wrong and they jumped all over me... like ***s
04 GMC Sierra
-15.168 @ 90.73 mph
Official Member
12-03-03, 06:36 PM
ic. its all good...i didnt know WHERE that **** came from.
97ekcoupeb18c1
Official Member
12-04-03, 01:47 AM
couldn't you atart with a 96-98 motor and do a h/c/i swap from a newer 6? maybe take advantage and do a little p&p job to the heads and intake and get a custom cam. isn't the bottom end the same throughout the years?
93 no option Notch
3150 w/me
Official Member
12-04-03, 11:08 PM
hard as heck..don't do it...been there done that...you have to swap:
exhaust
engine
tranny
driveshaft
rear axle
clutch
radiator
fan
master cylinder
computers
wiring
and a ton of others...sell your car and buy a cobra from the same year..for the money you will pay..
CHECK OUT MY WEBPAGE
307 RWHP 340 RWTQ and no traction!
USED TO BE A V6
13.56 @ 104 with a 2.02 60ft
302 all forged stroker, VT stage 2 p&p heads, pi intake, custom grind comp cam, comp valve springs, SCT dyno tune, cobra oil pump, vt gears, 7 qt pan, SPEC stage 3 clutch, 3.73 gears, jba headers, mac prochamber, borla side exhaust, tokico illumina 5 way shocks/struts, baer brakes all 4, granatelli upper and lower control arms, every bolt on...
custom stereo, dynamat, kicker l7's
Official Member
12-04-03, 11:28 PM
I am currently in the process of doing a split port swap, but I'm doing it on my existing short block. Dropping in the new engine is less of a challenge compared to what I'm doing. I believe you have have to switch the cam position sensor when you change the whole engine. And you have to get a modified fuel rail. Go to rpm-mustangs.com or velocitymustangperformance.com Chris_Red_V6 @ V6Power is selling is split port motor currently so might want to look into that.
In short
Take old motor out
Change Cam Position Sensor (maybe?)
99+ intake tube (just get an E-bay CAI)
Modified fuel rail
New motor in
Have fun.... You still won't be quite as fast as the 99+ guys though because they have 3.27's in the rear, but there is an abundance of those gears available on E-bay.
Official Member
12-05-03, 06:31 AM
Quote:
In short
Take old motor out
Modified fuel rail
New motor in
viper...don't forget everything else that i mentioned above...you are forgetting a ton...where the 6 and 8 cylinder parts are different...radiator, fan, master cylinder, exhaust, wiring, computer...etc..
Official Member
12-05-03, 08:04 AM
I believe Viper is talking about switching to an 6-split port set up and not a modular 8
12-05-03, 05:06 PM
keep the 96 motor....or well the single port just like you have spend the money you will save on a cam, heads, intakes and you will put down more HP than the 99 up can with the same mods..... more power for cheaper
2003 Cobra Vert - Redfire
Borla Stingers, H&R Race, MM CC Plates, MGW Shifter, JLT CAI, etc... Dyno: 400/380
12-05-03, 05:07 PM
Go the v8 route if you are considering doing an engine swap. My swap including all parts listed above and labor was 6 grand. I still (legally) pay v6 insurance and have a helluva lot more hp/torque now.
12-06-03, 12:16 PM
the v6 to v8 swap is too much out of the budget, plus he already has a blower (procharger p1sc). has any one actually ever done the swap or know someone that has?
by the way thanks to all the replies.
1994 Cobra 5.0L 5/spd
ISKY CUSTOM GRIND
Saleen headers,BBK offroad X pipe,MAGNAFLOWS
3.55 GEARS,17" CHROME 03' COBRAS
255/40/17 FRONT, 315/35/17 REAR
FORD INDIGLO REAR EMBLEM
DOUBLE CROSS SUBFRAMES
HPM Megabite jrs. lower control arms, NO QUAD SHOCKS
INDIGLO GAUGES, PHANTOM 5" TACH W/BLUE SHIFT LIGHT
BOOST,STOICH,AND F/P GAUGES
CENTERFORCE D/F CLUTCH
MSD Digital 6
AFR 165's
P600B @ 14Lbs.
Front and Rear Cross Drilled and Slotted rotors
12-06-03, 04:46 PM
why start with a 96-98 motor when you could start with a brand new one? sides it's not like ford makes brand spankin new 94-98 single port motors any more...
hey 98stangv8 next time what do yah say you actually read the title and post before you try to answer...
04 GMC Sierra
-15.168 @ 90.73 mph
12-06-03, 05:43 PM
if your insurance catchesup to you, you are in HOT doo doo.... they will not pay.
Official Member
12-06-03, 06:09 PM
Just get a Cobra!
