12-03-03, 10:22 AM
with the 4.30s you are in 4th when you cross the line, I would bet with 4.56's you would also be in 4th while crossing the line
1996 Cobra
Steeda Tri Ax, K&N, Air silencer removed, Spec stage 3 clutch, UPR Extreme triple hook quadrant with firewall adjuster, 4.30's, Eaton LSD 31, Moser 31 spline axles, BASSANI CB, VRS O/R x-pipe, and MM K-member brace, Bilsteins on all fours, Ford racing ALDS, Raptor shift light, 03 Cobra rims with Nitto 315's on the rear
