Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Power Adders
Reload this Page Whos done their own junkyard turbo setup?
Notices
Reply
(#1 (permalink))
Old
hoss331stang's Avatar
Official Member
Question Whos done their own junkyard turbo setup? - 12-03-03, 05:46 PM
check out my sig.....with a turbo i would only want around 550-600 FWHP. what size turbo would i need to complete that HP need. the motor should put out 450 FWHP as it is now. I want this to be as cheap as possible. Can somebody help me with turbo sizes and how much it should cost if i do it myself? Thanks.
(#2 (permalink))
Old
Spyderd68's Avatar
12-04-03, 01:09 PM
www.turbomustangs.com that is all you need.
Dave
Vortech A-Trim @ 11psi, 80mm C&L, 30psi squirters, Holly AFPR,255lph pump,3:73 gears,BBK long tubes, O/R h pipe, Flow's, ZT-5, Zoom Clutch, Tri-Ax, Aluminum D/S,130 Amp Alt., 17inch Chrome Cobra R's, Cervini's Cobra R hood, Saleen wing, Stalker bumper, Steeda lower control arms, Bilsteins,Sportlines, MM CC Plates.
13.20 @ 111mph with a 2.2 60'
2003 Yamaha R1 - Sliders, Scotts, -1/+2 sprockets, speedo healer, D&D.
(#3 (permalink))
Old
DirtyD916's Avatar
Official Member
12-04-03, 08:13 PM
friend did one on an integra. some good numbers but could have been better and more reliable imo if he went with a kit from a company or something like that.
(#4 (permalink))
Old
droptop93's Avatar
12-08-03, 09:12 AM
Quote:
Uhm, you didn't show your sig. so I can't tell you for sure. But if your putting down 450hp as it is...best bet would probably be a pair of GN turbo's, as they should be a pretty good fit for your power level, and have a pretty large aftermarket as far as upgrades for the turbo's if needed.
You could also use a pair of smallish T4's if you can find em. I would look for something around .8x a/r exhaust housings (maybe larger, I don't know what all you have done)...and if your just looking for around another 100 horsepower, .60 a/r compressor housings should be fine.
I wouldn't do a single unless your wanting to make more power than that. It would be pretty pointless to pay more money for a large frame turbo if your only looking for another 100/150 hp. But the 60-1 hifi would probably be a good fit if your definately wanting to go single, but your not going to find one of those in the junkyard.
I'm looking to get 550rwhp with a pair of Buick .60 / .82 T3's (from the early drawthrough 231's), around 12psi, and a large intercooler. This is going to be on a stock block 351 with forged internals, afr 205's, tfs-r upper and lower, and a custom cam. Should be optainable with alittle help from a tweecer.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Turbo modified into belt driven ???? jones 5.0 Tech 34 10-23-06 12:40 PM
