Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Reload this Page posessed fuel pump?
Notices
Reply
(#1 (permalink))
Old
Question posessed fuel pump? - 12-03-03, 09:56 PM
i've got a 93 2.3l and the damn fuel pump will just shut off at random. I've replaced the fuel pump for a different problem, and i know the inertia switch is good. I wanna know if there is anything else that might cause this problem. The only pattern i can see to the stalling is it will stall after running for a short time right after running for a long time (ex. Drive 20 min to nearest big town, stop at one place, drive 2 min to another place, when i start the car after the second stop, the fuel pump starts acting weird. It might die right after i start it, or 10 min afterward, but it always stalls.) After the car dies, i can sit and keep trying the key and eventually, the fuel pump will come back to life and i can go, although the car has had fits of dying, then working for 30 sec, then dying again. Some days the car won't die at all, and others, the car will fail 6 or 7 times within a 10 min peroid.
HELP!!!!!!!!!!!
(#2 (permalink))
Old
ib_steed's Avatar
Official Member
12-04-03, 12:04 AM
wow that is realy inconvenient!! bet you get a lot of people honkin at ya!
just thinkin what all is involved with the fuel pump... the pump itself... the electrical connections... the inertia switch... the fuel pump relay, ive heard of relays acting up but i dont know what they do when they act up. thats all i can think of... hope that will spur something in someone's head...
-Steed
(#3 (permalink))
Old
Teen'93stang5.0's Avatar
12-04-03, 02:06 AM
it sounds like a faulty inertia switch, but try replacing the relay first, its only like 5 bux, if that doesnt solve it then try the inertia switch
had the same kind of problem after i swapped in a 302 into my 93, the relay got knocked loose during the swap and was getting an intermitint signal
Stangless ........for now........
2003 Audi A4 Sport (severely underpowered)
...not a newb...
(#4 (permalink))
Old
ssjmaverick23's Avatar
Official Member
12-04-03, 08:25 AM
check your power relay mine acts up from time to time
(#5 (permalink))
Old
12-05-03, 11:51 PM
What kind of pump did you use as a replacement? Some pumps require you to ditch the resistor wire that goes to the pump. What happens is the wire heats up increasing it's resistance, cutting current to the pump. Then it cools enough, allowing you to start the car and run for a while. One of these about drove me crazy till I jumped the pump to the batt. Then it was a real "Oh, ooookay" kind of moment.
(#6 (permalink))
Old
Demented5oh's Avatar
12-06-03, 07:47 PM
I have a similar problem that I have related to the wiring going to this box what ever it is... If i move the wires while car running the pump will start, stop, start, stop and so on.
http://forums.stangnet.com/attachmen...achmentid=9354
(#7 (permalink))
Old
12-06-03, 09:03 PM
BTKiller, is that a '92/'93? If so I'm betting that "black box" is the IRCM. The Integrated Relay Control Module. Really just a fancy name for a box with the relays for Fan, pump and EEC power in it.
Either the connector is corroded or maybe the wires are bad internally. Try using a little electrical cleaner on the connectors. (after un-plugging them)
If the problem still exists try doing a continuity check on the wiring. It may also just be a loose connector.
(#8 (permalink))
Old
12-07-03, 04:49 PM
It is acutally a 91 but I belive is same as 92 & 93... Thanks I will try it
(#9 (permalink))
Old
12-08-03, 05:20 PM
yep, thats the little black box on the shock tower
...not a newb...
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
