Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Power Adders
Reload this Page Nitrous on 99+GT's?
Reply
(#1 (permalink))
Old
Official Member
Nitrous on 99+GT's? - 12-04-03, 12:45 AM
Anyone runnin' nitrous on a 99+GT? What kinda times you runnin? What system are you runnin'? Any other info you got. Thanks.
(#2 (permalink))
Old
LS2 KLR's Avatar
Official Member
12-04-03, 08:06 PM
I just dynoed 328rwhp/420tq and need some tuning. I'm hoping for low 12s. After I have it tuned I'm going to head to the track!
99 35th: 200 shot, 5.0 stroker, VT Stage 2 heads/cams, Bullit intake 3.73s, BBK long tubes & x-pipe, 1 chamber Flows, Aeromotive return style fuel system, Spec stage 3, and 17x8/17x11 Torque Thrust lls on 315 Nittos and all the suspension goodies
325rwhp/362rwtq
536/645 on the gas
*Daily Driver
Twin 60s going on shortly
(#3 (permalink))
Old
Official Member
12-04-03, 08:58 PM
Quote:
Which system are you runnin?
(#4 (permalink))
Old
LS2 KLR's Avatar
Official Member
12-04-03, 10:43 PM
I'm running an Edelbrock dry with purge, heater, and a remote bottle opener. What I liked about this kit is it comes with a fuel boost a pump. While I was having it dynoed they asked if I wanted to convert it to a wet kit but I didn't see the point, but at least I know I can if I ever need to.
(#5 (permalink))
Old
12-05-03, 02:53 PM
Im running the Zex kit (Wet) on my 99gt. So far the best times I have 13.4 with the 75 shot and 13.1 with the 100 shot at 108mph. The biggest problem so far is traction, my sixty foot time 2.2. Need to buy some Nitto. I have had no problems with the Zex kit and it was easy to install. I also installed a MSD window switch for a little more safety and a bottle warmer.
(#6 (permalink))
Old
12-06-03, 03:43 PM
Quote:
I have a 2000 saleen(no blower/251rwhp stock)Probably close to your numbers? Using NX wet kit, 150 shot. Just ran a 12.34 last night. This was on street tires and I'm pretty much a novice driver. Kinda hard to hook up, but once you do, its balls out. I HIGHLY reccommend this kit: easy install, safe, good tech support,minimal tuning required. Numbers are rated at the wheels,not the flywheel like everyone else. Whatever kit you use, your car is gonna fly! Have fun.
(#7 (permalink))
Old
Official Member
12-06-03, 04:41 PM
I was able to run 12's (12.0-12.1-12.2 @ 115-118) all day. I would actually slow down a little near the end so I didn't go too fast. I would just shut the switch off almost as I crossed. I was told if I went under that mark I would have to get so mods done before I could run again. Oh, and you'll never be able to hit the juice in 1st gear.
NOS "dry" kit.
Loved it.
Vortech
SCT Tuner
SCT Raptor
Snow Meth/Wate Inj.
DynoJet Wideband
TKO 600
Lake Bell
Alum. Flywheel
Center Crap clutch
KB BAP
(#8 (permalink))
Old
12-07-03, 09:41 AM
are u guys runnin the stock intake manifold. I have heard very bad things about backfires happing on those plastic intakes. Is any one runnin a after market intake like the reichard or bullit intake with n2o?
(#9 (permalink))
Old
12-07-03, 07:01 PM
Quote:
Been spraying a 150 shot for several months on the stock plastic intake. Just don't hit the rev limiter and you'll be fine. I have an auto and my limiter is raised to 6500 to avoid this. I can't hit it unless I hold the gears in 1 or 2.
I ran a 12.37 @ 108.8 on the 150 shot. My bottle pressure dropped halfway through. I could have ran an 11 on that pass, but the bottle was almost empty and didn't want to stay above 900psi. Oh well...
(#10 (permalink))
Old
1sweetGT's Avatar
Registered User
12-08-03, 08:55 PM
I got good results with a dry kit and mods listed below.
(#11 (permalink))
Old
12-09-03, 03:42 PM
Nice numbers! I'm using the stock, plastic manifold also. I've had no problems so far on a 150 shot. The key is not to detonate(of course), as long as the combustion process is moving THROUGH the manifold, you're ok. The plastic manifold is actually much lighter and it dissipates heat much better than aluminum and steel. Tune your ride properly and respect the juice, you'll be fine. The horror stories will be just that...stories. Get the NX bottle heater. I get 1000 psi with that bad boy if I have 10 lbs or 2 lbs in bottle. It's a few bucks more, but well worth it. I had a Zex heater and the two don't even compare...IMO.
(#12 (permalink))
Old
Official Member
12-09-03, 08:07 PM
I have a 01 GT and I am running a ZEX wet kit. I run a 13.7 N/A but I don't know what I am on the juice due to the weather(track being closed). Should be in the 12's now. I am running a 100shot and my car really rips now, n20 is a blast, Get it!
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Nitrous express NXL kit 2000 4.6 4.6 Tech 7 12-31-03 09:47 AM
