This THREAD brought to you by... |
Pro 5.0 Shifter Ques. -
12-04-03, 10:43 AM
I recently bought my 1997 Cobra, and the guy I bought it from has the Pro 5.0 Short throw installed. Well I don't really like the shifter handle on it because its freezing cold on cold days, and it makes my hand semi-slip and sometimes almost miss putting it into a gear. I have tried to take it off numerous amounts of times, and it seems like its either put on by some tuff guy, or some tuff thread lock, my last guess which I'm thinking it is.. They didn't come with a handle already attached to them do they? If not, have any good advice on taking the old one off.. Its Polished Aluminum thats why I cannot get a good grip.
1997 Mustang Cobra
BBK CAI
March U/D Pulleys
BBK H-Pipe
Flowmaster Cat-Back
Welded Subframe Connectors
Pro5.0 Shift
'03 17" Cobras
Official Member
12-06-03, 08:05 AM
No they don't come with the shifter knob attached. My only suggestion is to take the actual handle off of the shifter base, put it in a vise, and take the knob off with a pipe wrench. Be careful not to bend your handle. Of course, the pipe wrench is going to mangle the knob...but I'm assuming you want it dead anyway.
'90 Saleen Hatchback #163
C&L 76mm MAF, FMS 65mm TB, GT-40 intake, 24lb injectors, Adj. fuel pressure regulator, Twisted Wedge heads, TFS Stage 1 cam, BBK 1 5/8" ceramic shorties, Dr Gas X-pipe, Magnaflows dumped, underdrive pulleys, MSD coil, 373's
Maximum Motorsports C/C plates, MM strut tower brace, MM 4 point K-member brace, MM subframes, H&R race springs, Bilstein's, MM adj. lower control arms, MM panhard bar, MM Torque Arm
Officially Addicted
12-08-03, 05:14 AM
Is the knob held in with a set screw?
Check out RNH Performance Performance Engines and Custom Fabrication. From Mild to Wild we can build what you want, when you want it.
Official Member
12-08-03, 10:33 AM
Quote:
Hmm. When I got my Steeda Tri-Ax, there was something in the instructions about Al knobs on the handle. I think it said something like "never put on an aluminum knob without using some type of metal grease.... or something...." Maybe that's what happened-- whoever put it on didn't use that stuff and it's just really stuck on. Maybe a squirt of WD-40 would help?? See, and it sucks that Al handles get cold in winter and hot in summer and that's why I won't bother with Al knobs. Hope you get that thing off without breaking anything.
Take care.
'79 Mustang notch
5.8L; C4, Transgo shift kit; Holley 750, Edelbrock Performer RPM intake, 1 5/8" MAC shorties; Fluidyne Al radiator, Flexalite electric fan; FRPP Al ds; S&W 6-pt cage; 2.5" Off road H-pipe, 2-chmbr Flows; 8.8" w/ 3.55s; Welds, Nitto Drags; K&N X-stream air filter.
'92 GT (5-speed)
2-chmbr Flows, MAC CAI, Tri-Ax, Al pedals...
Officially Addicted
12-08-03, 11:47 AM
They were most likely talking about Anti-Seize..
I hate to suggest it but maybe adding a little heat would help if it is seized up.
12-18-03, 09:04 AM
I don't think theres a set-screw, at least to what I see when I look at it. I pulled the boot down a little bit to check 360degrees around. It sounds to me like its Antigen351W said its prolly stuck on there good between the 2 metals, but I never heard about that before.
I have tried so many things already, like jar openers, that thing "as seen on tv", I would like to stay away from heat, I dont wanna torch in my car. Im kinda accident prone..lol :P
1997 Mustang Cobra
BBK CAI
March U/D Pulleys
BBK H-Pipe
Flowmaster Cat-Back
Pro5.0 Shift
'03 17" Cobras
12-21-03, 04:48 PM
I thought Steeda only warned you about putting an aluminum knob on an aluminum handle.......but anyways, sounds like you have a plan. Try that jar opener thing with the rubber strap, I've heard they work very well.
12-22-03, 12:47 AM
use a pipe wrench
Official Member
12-25-03, 03:09 PM
yea use a pipe wrench, just put a cloth or something like that in between the grips and the shifter itself, that way you don't tear the hell out of the knob...if that slips you can use one of those cap opener things....(little rubber thing that grips stuff)...  If that don't get it, i don't know what to tell you.....
12-27-03, 07:20 AM
remove THE SHIFTER HANDLE OUT SO U DONT MESS UR GEARS UP TEARING THAT THING APART!... BE a man metal isnt so bad on your hand! Hey I got a Ford motorsport real Carbon Fiber 5 speed gearshift Knob Very nice looking? interested 35$ shipped worth 120 at ford dealer.
01-02-04, 12:27 PM
Get a rag put it over it and then tighten a hose clamp on it. Then use a pair of vise grips on the hose clamp and twist it of. It works every time and it doesnt do any kind of harm to the knob.
332 Eagle stroker
Victor Jr intake
Solid roller cam
Intake Exhaust
.614 .621
248 254
7/16 CC roller rockers
750 Mighty Demon
AFR 185 heads
All msd ignition
Edelbrock race fuel pump.
Hooker super comp headers
Lakewood scattershield
Centerforce clutch
T5Z trans
Steeda shifter
Northern Aluminum radiator
620 coils
5 leaf, leaf springs
9" detroit locker, 4.30 gears. Moser 31sp axles.
Official Member
01-13-04, 01:33 AM
supa big vise grips!!!!
Scott
Quote:
When devils will the blackest sins put on,
They do suggest at first with heavenly shows. - Othello
Scott - '95 GT - Triple Black Vert
DSS 306 forged and balanced short block
Trick Flow Track Heat H/C/I
Tweecer R/T, C&L MAF
FRPP lifters/RR's/30lb. Inj's/3.73's
BBK Headers, Magnaflow C/B, Bassani O/R X-Pipe
MGW Shifter and other goodies!!!!
2006 Yamaha Blue YZFR6
http://www.myspace.com/scottydoesntknooow
How to install gears!!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
