I'm not sure, but I don't think it will. I tried fitting a amp under the passenger seat, it contacts some of the seat but fits. There would have to be no or a very small enclosure. You'd probably have better luck with an 8" sub.
I couldn't even fit an amp under the seat of my '88 GT... well at least not the big amp.
2003 Sonic Blue Mustang GT
K&N Filter
Magnapack Cat-Back
Bassani O/R X-pipe
BBK LTS
Pro 5.0 3.90s
UPR Shifter
Lots of Steeda Suspension parts
A lot of car audio stuff
NEW Best ET on 5/27/05 - 13.513 @ 103MPH w/ a 1.854 60FT time on D/Rs
1988 Mustang GT - Sold
Shelby GT 500 will be in my garage
Anyone with a convertible ever pulled up the back seat pad? Looks like if the support bars were removed, and some boxes were made to both hold the subs and support the seat pad...it would work.
I have a pair of 12's in my "trunk", and it's an absolute pain in the ass. The box leaves no room for anything besides my battery.
You definitely won't fit a "normal" 8" or 10" sub under the seats. The Subaru WRX has a sub under the passenger seat. I'm not sure what size or how it sounds but you might be able to retrofit it into your car. There's also this Panasonic which seems to be pretty similar. I doubt it sounds great, and it only goes down to 40Hz, but it IS small. http://industrial.panasonic.com/www-...AIA0000CE4.pdf
Blaupunkt also makes some VERY low profile subs for use in very tight spaces. They're only a few inches deep. I was considering using something like this in my spare tire well so that i can keep my spare AND have a sub instead of one or the other.
