Wood, under the hood you only wire in the vam, it's that easy. Like said, the act is already in (if you use your existing n/a intake) and wired.
Quote:
Also with the preimum wiring jumping, if you are using a gillisboost controller do u need to even mess with that wiring?
Yes you do. The boost control and the octane switch are different. Boost control you will not wire into the computer and use the Gillis. Premium switch is to tell the computer what octane you are running.
The Premium setting you can run a switch to turn it off/on so you can use hi or low octane. Or, you can just wire it straight, no switch, run hi octane and know your computer is giving you the most aggressive tune all the time.
Cro did his wiring swap in about 15 minutes, pretty well shocked me. I was finishing something and getting ready to come help him when he announced it was done. Real easy.
