Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Reload this Page Anyone with sound dampener install notes?
Notices
Reply
(#1 (permalink))
Old
di0de's Avatar
Anyone with sound dampener install notes? - 12-06-03, 10:29 PM
I'm going for either the B-Quiet for FatMat dampener and wonder if I should attempt to install this myself or let someone else handle it? I'm completely confident removing the door interior parts, and can probably figure out the rest, but have no clue how easy the actual application is. I'm thinking of just doing my doors, rear seat arm rests, and maybe some on the trunk..
(#2 (permalink))
Old
Ruffrider's Avatar
12-07-03, 10:04 AM
I installed eDead pretty much everywhere but the roof so far.
They make different versions for different parts of the car. Like with the eDead V.2, they make it from use in doors, the floor, and trunk... and than ussually have you put a layer of V.1 over top of it for UV/Heat protection.
If you let the stuff sit on in the sun, or use a heat gun, it will be a little eaiser to work with. I'd also reccomend getting a small roller for the spots the are hard to get down. Also, cleans the hell out of the surface your appling it to or else you may have problems getting it to stick. I used 3M Super 77 spray cleaner to clean all the stuff off.
Other than that just remember its VERY time consuming. It took me a good 4 or 5 days to complete my car, but I did pretty much apply it everywhere. It's worth it though
http://www.edesignaudio.com/ep2/edead.htm
2003 Sonic Blue Mustang GT
K&N Filter
Magnapack Cat-Back
Bassani O/R X-pipe
BBK LTS
Pro 5.0 3.90s
UPR Shifter
Lots of Steeda Suspension parts
A lot of car audio stuff
NEW Best ET on 5/27/05 - 13.513 @ 103MPH w/ a 1.854 60FT time on D/Rs
1988 Mustang GT - Sold
Shelby GT 500 will be in my garage
(#3 (permalink))
Old
yellow83gt's Avatar
12-07-03, 11:30 PM
eDead V.2 isn't available anymore, but they're coming out with a new liquid deadener to replace it.
http://forum.soundillusions.net/showthread.php?t=30563
(#4 (permalink))
Old
Ruffrider's Avatar
12-08-03, 08:10 AM
Well I must have gotten mine just in time. It was only a little while back when I installed it.
(#5 (permalink))
Old
BBrinks's Avatar
12-08-03, 12:19 PM
It's pretty time consiming if you do it yourself. Like Ruffrider said, get a wallpaper roller ~1.5" or so, and a heat gun and it really saves a lot of time. Also, measure the area first before you cut the deadener, and work with somewhat small strips. Cleaning the area is a VERY important step, and if you don't do it properly, you will notice it to start to peal away from the door skin later on. It's not too bad if you do it yourself. It took me about 6 hrs. per door to do two layers. I could have done it a lot quicker, but I wanted to get it done right. I also removed the wires to run the deadener under them. I can get some pics if you want. I'd recommend doing it yourself, though. It's worth it in the end if you know you did it right.
(#6 (permalink))
Old
di0de's Avatar
12-08-03, 01:24 PM
Thanks much for the info. So it's okay to cut this stuff into fairly small pieces to work it into the shapes of the car? I imagine that'd work out fine.. dunno if I could do it and have it adhere properly with large pieces though...
(#7 (permalink))
Old
BBrinks's Avatar
12-08-03, 10:38 PM
If you take your time, you'll do fine. If you heat it up pretty good to get it tacky, and use the roller to really press it onto the panel, and into the crevices, it adhere's really well. It saves some time to take out the christmas tree clips that hold the wiring onto the door and run the deadener under it, and make a hole through it to clip the wire back on. It looks cleaner and saves time trying to cut the sheet along the edge of the wiring bundle.
1994 GT 5-speed
Trick Flow Street Heat Intake
Walbro 190 lph fuel pump
3.73 gears
CDC side exhaust
CAI
Ford Racing Aluminum Driveshaft
245/45ZR17 Nitto NT555's all around.
(#8 (permalink))
Old
damacman's Avatar
Official Member
12-11-03, 09:53 PM
Doubling your amp power is good for 3 dB in gain and is LOTS cheaper. Use deadening material to lower the resonance of the sheet metal in your doors and you'll be rewarded with snappier and more extended mid-bass response from door mounted speakers. Use it on the backs of plastic panels to eliminate unwanted vibrations, etc. but don't waste your money applying it on every sheet metal surface in your vehicle.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
