Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Reload this Page 4v heads on a 2v
Notices
Reply
(#1 (permalink))
Old
carbed 85 gt's Avatar
Official Member
Question 4v heads on a 2v - 12-08-03, 12:33 PM
Ive got a 02 gt and will have some money for mods i wa thinking blower but would like to convert to cobra na way could 4v heads bolt on to a 2v and wht extra parts would be needeeed
(#2 (permalink))
Old
12-08-03, 01:49 PM
Dont waste your time, buy a 4V motor
(#3 (permalink))
Old
Official Member
12-08-03, 04:45 PM
Quote:
how about NOOOOO. I already have a block to work with if it fits Im not spending 3k on a used cobra engine. Your post didnt help one bit I asked if it could be done.. read my post
(#4 (permalink))
Old
Solid Snake's Avatar
Banned
12-08-03, 05:18 PM
THat kind of attitude won't get you far, I'll tell you that. He is right anyway. You would have to machine the block for the heads to work. That, plus a bunch of other things would run you MUCH MUCH MUCH more than simply dropping in the complete 4V motor.
(#5 (permalink))
Old
RedGTvert's Avatar
12-08-03, 05:42 PM
Quote:
He would not have to machine the block to make 4V heads work on an Iron block. The '03 Cobra basically uses a 2V block.
There are numerous things that will be needed to make it work, but I agree with one poster above, it will be easier and cheaper to buy a used 4V. Have you looked at the cost of 4V heads? They are not cheap.
(#6 (permalink))
Old
12-10-03, 08:25 AM
Quote:
Sell your GT motor & buy a Cobra motor. They share nothing in common except displacement. Also if your looking to build up a motor 400hp+ the 4v Cobra motor is much more robust, with it's forged crank & high quality AL block.
Get a Grip and Rip
(#7 (permalink))
Old
sinisterblack98's Avatar
Sometimes I just lay on my garage floor and look up at it.
12-10-03, 08:22 PM
Totally possible, no machining required if you don't mind a blower friendly 7.85:1 (or 8:1?) compression ratio. Worth it...not IMO...by the time you get heads, intake, computer or re-flash, and ancillary parts not to mention you should do a forged crank (the factory did).
If I would have had access to cheap parts, I was going to do this same project with a blower to my GT. Kar Kraft sells whole 4V crate motors for around $4500 bucks and you gain an aluminum block.
Or do what I did...just buy a Cobra!
1998 Black Cobra Convertible, Saddle/Saddle
#982 of 3480, 1 of 215 Black/Saddle/Saddle 'Verts.
4.10s, 31 Spline Cobra Limited Slip, Al Driveshaft, Steeda Tri-Ax, Clutch Pedal-Height Adjuster, Steeda Quadrant & Firewall Adj. Cable, K&N, BBK Offroad X, No Silencer.
Real Cobra "R" Hood, Spoiler-less Trunklid, CDC Lightbar, Chrome 17X8 & 17X10.5" '95 Cobra "R"s, 245/45/17 Nitto 555s & 315/35/17 Nitto Drags.
www.sinisterblack98.stangnet.com
(#8 (permalink))
Old
AikiRonin's Avatar
12-12-03, 10:49 PM
Maybe if you were starting from scratch it might be more cost effective to just buy a cobra motor...but what if you are already forged....and have the same cobra accessories....say like my Bullitt?....:O) you can extend your stock harness and have a chip burned for the PCM...or I suppose you could buy a Cobra PCM and harness.
John
(#9 (permalink))
Old
Hissmann's Avatar
12-13-03, 07:00 AM
If you were to use the heads from a 96-01 Cobra you could have seriouse problems. Aluminum Heads/Iron Block. Under heat and stress the two different metals react differently.
(#10 (permalink))
Old
AikiRonin's Avatar
12-13-03, 10:40 AM
Ok...so what about 03' heads? Or Navi heads....or maybe even Mach heads?
(#11 (permalink))
Old
Hissmann's Avatar
12-13-03, 10:44 AM
Quote:
03/04 heads would be your best bet.
(#12 (permalink))
Old
5.0's 4 ever's Avatar
The #1 Stunna
12-13-03, 04:22 PM
Quote:
Aluminum heads on an iron block have been a proven reliable combo for a while now. The 4.6 SOHC, 03 Cobra, 5.4 SOHC, 5.4 DOHC, and with the pushrod motors.
www.realstreetperformance.com
1996 Mystic Cobra built for turbo boost
Boss 330 Forged 283ci, 03 Heads, 99 Intake, Viper T56, etc...
2007 Lexus IS 250 daily driver
SOLD
88 5.0 LX Vert 434rwhp/408rwtq @10psi
91 5.0 LX Hatch
(#13 (permalink))
Old
Banned
12-14-03, 08:32 AM
The 2V SOHC utilizes aluminum heads and iron blocks. 03 Cobra utilizes aluminum heads and iron blocks
(#14 (permalink))
Old
12-14-03, 05:37 PM
Look in the Ford racing catalog for 2004, they're getting rid of complete brand new mach 1 and cobra motors for fairly cheap.
1997 Cobra Pacific Green
WMS Velocity tube w/ K&N
Pro/m 87mm maf
Steeda Tri-ax shifter
MGW Cobra satin shift knob
Eibach springs(cut one coil all around)
Tokico adj'ble struts/shocks
S-351 wing
Saleen '01 18x9 wheels
Nitto 555 265(frnt) 285(rear)
MagnaPak mufflers(welded into stock catback)
Best 1/4 mile=13.82@104.7mph w/ 2.22 60'
(#15 (permalink))
Old
AikiRonin's Avatar
12-14-03, 08:01 PM
Anyone think of anything else?
03' Cylinder Head ASSY W/Valves LH P/N: 2C5Z-6049-FA
03' Cylinder Head W/Valves Assy RH P/N: 2C5Z-6049-GA
03' Lower Intake Assy P/N: 2R3Z 9424-BB
03' Upper Intake Assy P/N: 3R3Z 9424-DA
Throttle Cable P/N: 1R3Z9A758CA
Cruise Cable P/N: XR3Z9A825BA
Over flow hose P/N: F8ZZ8C350AA
Stat Housing P/N: F6ZZ8592BB
Stat housing P/N: XR3Z8K528AA.
Lower Hose (Rad-Housing) P/N: 7ZZ8K576AB
Lower Hose (block-Housing) P/N: F7ZZ8K576AB
Upper Rad Hose P/N: F7ZZ8260AA.
Bypass hose P/N: F7ZZ8A593AB.
Timing Chain Cover P/N: 2R3Z-6019-BA
John
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Rick Swain 96-98 Heads vs 99 PI Heads stormshadow 4.6 Tech 68 12-05-04 01:19 PM
calling all head guru's !!!! which heads will produce better gains slo95.0 94-95 Tech 23 02-24-04 03:30 PM
