This THREAD brought to you by... |
Clutch pedal vibrating?? -
12-10-03, 02:49 PM
I've noticed something weird with my 96 cobra...probably not anything to worry about but thought I'd mention it. When I'm in gear, when I get to around 2000 RPM (when I let off the gas and slow down and the rpms are slowly dropping) You can hear the clutch pedal shaking or vibrating. If I slightly put my foot on it, I can feel a little vibration in it. Is this normal? Everything else seems fine, no problems shifting or anything....
1996 Cobra. White/Tan Leather, 69k miles. Flows, lowered, 98 cobra wheels, open air K&N
67 Fastback. 289, C4, Clearwater Aqua, Aqua interior. Crane Hi-6 ignition, Mallory Unilite Dist., Holley 600 CFM carb, Comp Cam 268H cam. C4 with shift kit. Hooker competition headers. Mac Flowpath mufflers... 2.5" piping, h-pipe. Aluminum DS. Lots of unnecessary chrome pieces
16 " Repro Magnum 500's, Kuhmo ecsta tires.
Banned
01-05-04, 03:01 AM
my 91 GT did the same thing, you need a new clutch dude
Mr. Metrosexual
01-05-04, 04:46 AM
Quote:
My car does it to. It is not that much, but it does vibrate ever so slightly. I have just over 11,000 miles on it. You think it needs to be replaced?
Busted Buffing the Bishop
01-05-04, 11:26 AM
Mine never did that, until I replaced the stock clutch, throwout bearing, and pressure plate for a SPEC stage I clutch and lightened pressure plate. I also had my flywheel resurfaced.
Does the vibration go away if you push in the clutch all the way? If it does, that means that mechanically you are fine. Mine vibrates all the time, sometimes i'll be idling and i'll hear a grinding sort of sound. I am told it's the pressure plates fingers not all lining up, and while its an earsore, mechanically it's not harming anything. On the other hand, some guys are saying this can wear out your throwout bearing faster, and you need a firewall adjuster or something to fix the problem.
Anyways, try searching, or maybe someone else will respond her. I know this topic was discussed about a week ago, and people were posting a lot of info. The vibration really p!sses me off at points. It sounds like chattering teeth at times. Sometimes you can even here it chattering outside the car at idle, easily over my exhaust. It sounds nasty too, not the kind of sound I want to be heard.
Old: Supercharged '95 Maxima SE 5spd
Gone but not forgotten: '97 SVT Cobra, Black on Black - Bassani CB, UPR X-pipe, 5% tint, grille snake, red brake calipers, cobra inserts, shorty antenna, smoked diamond headlights, '03 SVT 18x10.5's, 4.10's, Eibach Sportlines, Steeda CC plates, Steeda Firewall Quad Adjuster, King Cobra clutch, Steeda Tri-ax, Steeda T/A, Anderson Induction, Saleen wing
13.8@106.2 w/2.27 '60
Looking for a 99-02 Lightning or 96-03 Cobra
Official Member
01-05-04, 02:00 PM
My 97 does the same thing, there is actually a TSB from Ford on that issue. TSB 00-24-1 I would'nt replace the clutch without getting a print out of the TSB. It has a few things to check first, hope this helps you out.
Registered User
01-05-04, 11:01 PM
Yep i had the same problem in mine. I needed to replace the Throw Out bearing and the vibration was gone.
Mr. Metrosexual
01-06-04, 12:51 AM
Quote:
Every once in awhile, after I release the clutch, I hear a noise. It is hard to explain the sound.....kind of like a shutter that lasts for a second or two. Anyone know what I am talking about? Is it the TOB?
01-06-04, 11:35 AM
Quote:
I have that too. It is a loud vibration and the pedal shakes like mad for about a second after I let off the pedal. I firmy believe it's the pressure plates fingers causing all the roukus. I KNOW it's not my throwout bearing, becuase it's brand new along with everything else.
01-08-04, 02:08 PM
Mine did it too when the clutch flywheel and throw out bearing were all worn out. It was crazy I could look down and see the pedal pulsing up and down. So I bought a SPEC stage 1 and a new flywheel (stock). Along with all that I bought the steeda adjustable clutch cable, firewall adjuster, and quadrant. It works great now still makes a weird sound when the clutch is out in neutral. I think it needs a new shaft (the thing that the TOB rides on) it looked pretty worn I heard they make a hardened steel one. But dont feel like going though the pain of ripping the tranny out. I hope that helps you out in some way.
1996 Cobra:
NX 150 SHOT
4.10 GEARS
KENNE BROWN SUB FRAMES
STEEDA TRI-AX SHIFTER
K&N FIPK
SALEEN 18X9(FRONT) 18X10(BACK) RIMS
FRPP ALUM DRIVE SHAFT
MOSER 31 SPLINE AXLES
EATON 31 SPLINE LSD
MEGABITE JR. UPPER/LOWERS
MSD WIRES
FLOWMASTER 3 CHAMBER CAT BACK
BBK X-PIPE (SLP in the mail)
COBRA RR HOOD, SALEEN SR800 WING
INTRAX LOWERING SPRINGS (2" DROP)
TOKICO 5-WAY ADJUSTABLE
STEEDA TIMING ADJUSTER
BFGOODRICH COMP T/A DRAG SLICKS ON 15X8" RIMS
Mr. Metrosexual
01-08-04, 04:02 PM
Quote:
What do they do exactly? Does anyone care to explain them to me? Thanks.
01-08-04, 06:30 PM
they allow you to adjust the play in your cable. the quadrant makes it a little easier to push the pedal in. The stock quadrant is made of plastic and with having a steel cable you can guess what happens over time the cable starts to wear away the plastic quadrant. Take a look at the one you have on your car now it will be worn. Another thing is that with a heavy clamping pressure plate it puts more pressure on that stock plastic peice and it isnt all that uncommon for the plastic quadrant to break (the self adjuster is on the stock quadrant and it has plastic teeth). Now once you go to an aftermarket quadrant you lose that self adjustment. Now you can hope that with your brand new clutch and pressure plate that it will have just the right amount of play but do you want to risk having to spend another 200+ bucks on another clutch and all the labor that is involved because you burned up your new clutch in 500 miles when you could just get an adjustable cable and set it the way it is meant to be the first time? I hope this post helps you understand why it is important to do more than simply put in a brand new clutch.
Mr. Metrosexual
01-08-04, 10:36 PM
Thanks.
02-19-04, 11:01 AM
Mine vibrates also. It makes a cricket sound
When I place my foot on the clutch ever so slightly, the crickets go away.
How difficult is it to install the Steeda Quadrant and clutch cable? Is it more difficult than installing a Triax?
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
