Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Power Adders
Reload this Page Plug thread lengths
Notices
Reply
(#1 (permalink))
Old
Question Plug thread lengths - 12-10-03, 04:12 PM
14mm, .708" reach, half thread, 5/8" hex, tapered seat, resistor, power tip, copper core, nickel plated
14mm, .708"(18mm) reach, 5/8" hex, tapered seat, resistor, projected tip, V-power (v-grooved center electrode), .039"gap
I have a question about plugs for my 2002. I want to put some TR6s in, but it seems they have a longer thread than the stock plug. I am assuming this because motorcraft, and autolite ate the same. The stock replacement autolite has a half thread, and the TR6 are has a full thread. They both have the same reach. I know many people use the TR6, and ar103s, and ar94s, both have a full thread. I have not looked at the stock plugs yet, so am guessing from peoples comments on the lack of threads in the head, and the stock plugs having less threads they are a half thread plug. It seems all the replacement plugs, but the autolites are a full thread plug.
Will using the plugs be an issue? Will they protrude into the combustion chamber further, would this not cause hot any spots. They are tapered plugs will they seal correctly.
If someone who has experience with the thread length issue can shed some light on it for me I would appreciate it.
Scott
2002 Mustang GT 5sp
C&L MAF (off the car), Accufab Plenum & 75 mm Throttle body, Dyno Max Mufflers, Bunch of MGW bling, Grill delete, Chin spoiler, Fuel Door,100 Shot Waiting NOS 05116, Pedator, EX262AH cams, Catted prochamber, V2 SQ-s trim, Cobra Injectors, Lightening MAF, Focus pump
94 Mustang 3.8L 5sp
2001 Audio A6 - Wifes's
http://www.northbaymustangclub.com
For custom dog tags, zippos, pendants and more check out www.customdogtagszipposandmore.com
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Plug thread lengths sgramer 4.6 Tech 5 12-10-03 10:45 PM
