Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Race Tech
Reload this Page Torque Converter Help
Notices
Reply
(#1 (permalink))
Old
CanadianCobra's Avatar
Official Member
Location: I'd love to settle down if I could afford it.
Exclamation Torque Converter Help - 12-15-03, 11:49 PM
I installed a TCI Streetfighter converter in my C4. The company told me with my application it should stall out at about 2700RPM.
So I go to make a test run, and the car doesn't move until the converter hits the around 2700RPM. I mean it doesn't budge at all, the RPMs just climb until the converter suddenly kicks in and the car spins the tires hard.
Everything I've read about aftermarket converters says that the car still has the tendancy to creep forward even if you were not at the flash point. So am I being an idiot or is my converter not acting right?
On another note, I can make the converter stall out at 1700 or so, if I slowly raise the RPMs. Then if I keep climbing slowly, I can make it stall again at 2700. But if I just go pretty hard on the gas, it will only stall at 2700. Does this sound right?
(#2 (permalink))
Old
12-16-03, 12:50 PM
Hello,
Maybe it's something simple double check your shifter cable adjustments, and fluid levels.
My 3600 stall (stallion) moves the car out right off idle (1100rpm). My old converter 3000 stall (B&M holeshot) was similar.
Good luck, Jason
(#3 (permalink))
Old
12-16-03, 12:56 PM
I should add that the above is for normal street driving. If I punch it off idle the converter will stall up and blow the tires away.
Jason
(#4 (permalink))
Old
davs5.0's Avatar
12-23-03, 04:38 AM
You've defiantely got something wrong in there. Call the tech line at TCI and see if they can help you.
91 Bimini Blue LX HATCH AOD, New motor; forged 331, AFR 185's, Perf RPM intake, Lunati 51014 , 30lb inj, Edge 3000 stall, Lentech VB, 90/10's and 50/50's, 1.7 FMS rockers, HPM lca's, k&n, KB subframes, 180deg therm, pulleys, b&m shift kit & trans cooler, 190 lph pump, C&L 76mm MAF, FMS 65mm TB, 3.90 gear, MT ET streets, Black Magic fan, custom chip, Flowtech long tubes and dumped Flows.
New times 12.24 @ 109.9(87 octane/10 deg timing) 1.64 60'
(#5 (permalink))
Old
speedy66's Avatar
12-24-03, 09:09 AM
Not too savy on torque converters.. What exactly will happen when i go from a stock one to a 2600..What kind of thing will I notice except for the better launches?
66 mustang coupe-3 motors blown in 5 years!!!.
New motor on the way.. Can you say ROUSH!!!
(#6 (permalink))
Old
AXIStang's Avatar
12-29-03, 01:23 AM
Something is wrong. Call TCI tech line if you have everything installed properly. I called them a few weeks back theyre good peoples. It should be pulling fine off idle
(#7 (permalink))
Old
01-03-04, 01:58 PM
Quote:
When you talk about stalling the converter twice do you mean that the car torques twice? If so that is normal. Almost all stock vehicles will do that. So for your question does that sound right. Yes yes it does.
enjoy
(#8 (permalink))
Old
01-03-04, 02:00 PM
Quote:
I don't know what he could have done to install it wrong. The only thing I can think of is if he didn't get the convertor all the way into the pump. in that case it should make lots of noise. bend the flexplate. and destroy the trans oil pump. Trust me I know.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
What torque converter do you run???? Dan95-5.0 94-95 Tech 53 04-11-07 11:17 AM
torque converter leaking..? taylor4g63 Classic Tech 2 12-13-03 12:34 PM
