This THREAD brought to you by... |
Need help w/ Hooker Headers -
12-17-03, 08:35 AM
Hey guys, I broke down and bought a set of the Hooker Super Comp headers. They seem to be very nice, but I don't understand why one side came in two pieces and the other side is altogether. I'm sure that is the way they are supposed to be but why exactly? What is it I'm missing? BTW, these things came with absolutely no instructions.... so I'm really depending on you guys to give me some answers... I'm not sure if I should weld the one side together before or after I bolt the header on? Who all has put these headers on their car? What are some good tips so I don't have to learn the hard way? Thanks!
d
12-17-03, 09:06 AM
I can't give you too much advice, but did you get the Pinto 351w swap headers?
If you did, they should end up looking like this.
http://www.starshadow.com/~gael/pict...p/DCP04042.JPG
http://www.starshadow.com/~gael/pict...p/DCP04043.JPG
They should be slip fit, where you slip the one ends on and go from there. What I did was just kinda mixed and matched them, until I got it right. You'll be able to tell which way is the right way by how they lay out together.
12-17-03, 09:11 AM
They are slip fit and the head flange is cut apart like yours in the pics you posted. However the bends on mine don't look anything like yours (probably because mine is for the 302 II). Anyway what is the reason for providing a slip fit and cutting the head flange apart? And why only on the one side?
d
12-17-03, 11:58 AM
Quote:
d
Is it the right(passenger side) that is 2 piece? Some of the headers have the #1 cyl pipe on the pass side cut and it goes under the A arm. you install the solid piece then add the separate one in afterwords.
Mstng2 "A Mustang II is a Mustang Too"
1978 Mustang II 357W, (.30 overbore 351W, too many mods to list) Wicked Fun!!
2000 Mustang GT/Saleen S281SC (Un-Numbered)
12-17-03, 12:06 PM
It is the passenger side, but it is both the #1 and the pipe directly behind that one. I don't see as though you could pass these pipes underneath the A-arm.. they don't come down horizontally anymore than any of the other pipes. I guess I need to take some pics...
d
12-17-03, 01:47 PM
d
I installed a set of these on my II over 20 years ago, assuming that you got the model 6120's for a V8. Yes, the passenger side comes in pieces. Mine was in 3 sections I believe, possibly reengineered to just 2 now. In any case, it allowed for a slip fit installation, where the large section was installed from below and the pieces set in from the top. No welding is necessary, mine never leaked whatsoever. I recall a very easy and straight forward installation, with no clearance problems, and little if any jacking up of the engine necessary to get them in. The steering coupling being the only thing that needed to be unbolted to facilitate installation.
12-17-03, 02:26 PM
Very cool, yes I got the 6120s.. so it is to allow ease of installation, that is what I needed to know. I'll probably weld them anyway just for my peace of mind. Thanks guys for the help!
d
12-18-03, 03:44 PM
dmoody could you post you install and let us know what if any problem you have. I also just picked up a set and am waiting for them to be delivered.
Vince the Fabricator
12-18-03, 07:49 PM
I have the installation instructions that came with mine. If you guys want I should be able to get them this weekend & scan them.
12-18-03, 09:56 PM
Quote:
Those would be Headman hedders with their one and only patented pipe under the frame design
I have a modded set now "headman no more"
76 COBRA II 302
.040 over, flat tops, ported/polished heads, cranecam 272 duration .484 lift, Erson full roller rockers, headman headers, edelbrock intake and carb 600 cfm, 3.40 trac-loc
12-19-03, 06:23 AM
Yes Vince, that would be way cool to have the factory installation directions.  And on a seperate note have you thought of replicating the SSM Lift Bars?
12-19-03, 08:43 AM
I agree Vince that would be great... I'm still wondering why my set didn't come with any
Jeffnoel, I'm usually so slow to install things on the car that everybody else has done restored theirs by the time I get around to finishing just one part. Anyway if I get the cam I ordered in sometime and manage to get it installed, etc... then I'll be able to put the heads back on, headers, etc. But that could be several weeks. I will take some pictures though when the time rolls around that I do install them
d
12-20-03, 12:36 AM
Here are CanadianCobraII's Hooker Supercomp headers. Before and after ceramic coating. They are on the car, tight fit but not too bad to install.
http://www3.bc.sympatico.ca/Heemskerk/Headers/
Good luck
12-20-03, 06:05 AM
hey dmoody did you purchase them new? from where? and price? i have the doug thorley ones and i hate that darn #1 tube.thanks
12-20-03, 09:29 AM
Quote:
Originally Posted by 77mach1
What type of coating is that, who did it they look great. How has the coating held-up after installation?
12-20-03, 09:56 AM
Quote:
There is a new set on eBay with a $200 Buy it now option. Auction ends early Wednesday AM.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449239894
12-20-03, 02:03 PM
Quote:
Originally Posted by jeffnoel
Did you happen to see the bid now price is the same as the buy it now
why would anybody pick the bid now and get in a bidding war
76 COBRA II 302
12-21-03, 03:15 AM
The headers are a ceramic coating from a local company called 'Kool Coat'. I've had the headers on the car for about 6 months ( 3 months of driving) and they are just as shinny as the day I bought them. The owner of the company said that when they get dirty even 10 years down the road to wash them with soap and water and they will look new again. Pricey but worth it.
PS. My headers will look slightly different in the pictures because they have the flanges welded on, and a few pipes have been bent to go around my T5 bellhousing.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
