(#1 (permalink))
Old
Exclamation Rear-end - 12-18-03, 11:41 AM
Thinking about upgrading the stock rear-end of my '88 and had a few questions. I am planning on going into the mid 12's and possibly some juice in the future hopefully in the low 11's and mabye high tens. What will I need to be strong enough to handle this, and still use as a daily driver? I was thinking about going with 31 spline axles, ford motorsport 3.73, and an Auburn semi-posi unit. Any reccomendations against the Auburn unit. Or any suggestion to go with something else? What are some of you guys running. Thanks
(#2 (permalink))
Old
12-18-03, 02:45 PM
you can not rebuild the auburn unit that is the big drawback, most you can just replace the clutches. i personally would go with a spool or mini spool. stang sells a package that give you 31 spline with c-clip eliminators and 31 spline spool. that is what id get if i didnt drive my car on the road every day.
(#3 (permalink))
Old
cevtv's Avatar
12-18-03, 03:33 PM
Quote:
He just said it's a daily driver........
1992 Titanium Frost LX 5.0L Coupe (1 of 253). 5-Speed. Cobra intake, FRPP 65mm TB, Pro-M 75mm Bullet MAM, Pro-5.0 shifter, SPEC Stage 1 clutch, 3:73 gears, Fiore Micro-Click f/w adj., FRPP Alum. DS, FRPP Ceramic shorty headers, H-pipe, Flowmaster A/T cat-back, CGS subframes, HPM MegaBite Jr. LCA's, FRPP uppers, March Power & Amp pulleys, Moroso CAI, 3G Alt., FRPP Aluminum radiator, Lakewood 70/30's and 50/50's.
(#4 (permalink))
Old
12-19-03, 01:54 PM
that is what I would like to do, but as I said it is a daily driver. What do you guys reccomend about just rebuilding the ford oem unit, or can that handle the 31 spline axles. and I thought that rebuilding the unit all you can do is install new clutches. I didnt know the whole unit can be rebuilt, or can it?
All I am trying to do is rebuild the rear and make it strong enough to go high 11's without a problem, make it reliable, and still drive it on the street everyday (thus eliminating the idea of doing c-clip eliminators and a spool). Any other suggestions, I am always open to suggestions. thanks for the inputs.
(#5 (permalink))
Old
TIMMY2734's Avatar
12-19-03, 07:44 PM
Ford 31 spline trac loc, matching axles and 9 inch ends
(#6 (permalink))
Old
-86GTStang's Avatar
Official Member
Smile 12-28-03, 04:49 PM
Quote:
...A strong combination. What about a compleat rebuild of the rear, and adding a strong GIRDLE on to it ?
(#7 (permalink))
Old
blue66tang's Avatar
12-29-03, 11:49 AM
Why not jsut stay with the stock rear and ad some low gears. The 8.8 is a very strong rear and many guys run deap into the 10s with them. So a little reserch and you will probobly find out that a stock rebuild and gears will do you just fine. If you do anything other than i rebuild i would recomend some aftermarket axils and c-clip eliminators.
332 Eagle stroker
Victor Jr intake
Solid roller cam
Intake Exhaust
.614 .621
248 254
7/16 CC roller rockers
750 Mighty Demon
AFR 185 heads
All msd ignition
Edelbrock race fuel pump.
Hooker super comp headers
Lakewood scattershield
Centerforce clutch
T5Z trans
Steeda shifter
Northern Aluminum radiator
620 coils
5 leaf, leaf springs
9" detroit locker, 4.30 gears. Moser 31sp axles.
(#8 (permalink))
Old
12-31-03, 11:36 AM
Thanks guys, I am going to go with a stock rear, a rebuild kit, and some motorsport 3.73:1 gears. I received the gears for christmas I think for driving on the street, that it should be just fine. When the time comes to convet it into a car strictly for the track, then I will do the new axles and c-clip eliminators. I appreciate the help.
Caleb
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
