Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Reload this Page Lowered Front end
Reply
(#1 (permalink))
Old
jeffnoel's Avatar
Lowered Front end - 12-22-03, 06:49 AM
What's the best way to do it? Drop spindles, Cut springs (yikes). Major clearence issues?
(#2 (permalink))
Old
perce111's Avatar
12-22-03, 09:28 AM
Cut springs are the cheapest way to go.......do not flame cut.
Remember when you cut a spring you will increase [stiffen] its rate.
I personally run Heidts 2" spindles on my black car and have shortened coils [not installed yet] for my white car.
Either way works.
If I remember correctly I had to go with offset rack bushings to align my front end after installing the spindles.
Have a good one
(#3 (permalink))
Old
12-22-03, 10:14 AM
Quote:
I've got a pair of short springs if you want them, drop me a PM. I didn't realize they were short until after I put them on- what a shock. Really looked mean, though. With everything else stock and 205/60/13s on the front, everything still cleared bumps ok.
(#4 (permalink))
Old
jeffnoel's Avatar
12-22-03, 10:56 AM
Quote:
Are they cut stock springs or a Racer Walsh product? How much did they lower your front? I'm running 225/40-16s on the front so clearence may be an issue if it's too drastic a drop.
(#5 (permalink))
Old
12-22-03, 03:39 PM
I picked them up at a swap meet so I can't say if they were cut, heated, or just made that way. On my V8 Ghia, they dropped the front a good 1.5-2.0 inches. I had been running 205/70/14s, which is pretty tall and they rubbed pretty hard when making sharp turns. Those wheel/tires had a diameter of 25 inches. With the 13 inchers, no rubbing at all.
(#6 (permalink))
Old
JonDawg's Avatar
Mstng2 supplied me with my pair
12-22-03, 07:53 PM
Now, Why hasnt anyone suggested the drop spindles? If you added stiffer (stock hieght) springs, then it would keep your alignment in good standing.
If you do shorten the springs, you will need to get it re-aligned.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
