This THREAD brought to you by... |
Which shocks for best ride quality with Coilover's -
01-05-04, 06:42 AM
I am converting to coilover shocks on my 02 Gt Vert and want to know out of these 3 Bilstein, Koni, or Tokico's, which would give the best ride quality?
Official Member
01-06-04, 09:36 PM
I'm no expert but here's my .02 By ride quality...I assume you mean smoothness on the street, not performance at the track.
1. If money ($1000) is no object I'd get the Koni D/As. You can tweak the compression and rebound individually for a smooth ride. You can dial 'em up if you want to do some autox. Lifetime warranty.
2nd choice. Regular-valved Bilsteins. Non-adjustable but I hear the make for a great ride. $650
3rd choice. Koni Sports. Can't adjust compression, but rebound is adjustable, so you have some ability to dial in the ride.
4th choice. Tokico Illuminas and KYB AGX. Adjusts both compression and rebound with the same control. Not the best for adjustability, no lifetime warranty.
If you get new struts, let us know how you like 'em.
'90 GT vert, 3X black, daily driver
MM Full lengths, O/R H-pipe, Flows, 4.10s, pulleys, FMS aluminum D/S, five lug
MM cc plates-$130
Koni yellows $375
MM LCAs sold, G-load & strut braces-sold
01-08-04, 04:46 PM
koni da's are the way to go.. i run them on the notch with griggs coilovers.. the ride handling is great and the ride is stiff .. but can be adjusted softer..
not to burst your bubble on your coilover conversion.. but personally if you still want a decent ride i would go.. with a progressive rate conventional spring, eibach pro kit, mac, etc..
89 MUSTANG SALEEN... STREET CAR: SOLD
96 MUSTANG COBRA MYSTIC... STREET CAR: GETTIN A 322CI 4V
03 SUPERDUTY: 9" LIFT, 5" EXHAUST, EDGE JUICE, ETC..
THE ONLY WAY TO COUNT: 1-3-7-2-6-5-4-8
DRIVE IT LIKE YOU STOLE IT!!
ITS SAD WHEN A STARTER PUTS OUT MORE TORQUE THEN UR CAR ENGINE!!
01-09-04, 02:42 AM
I went with the Maximum Motor sports kit for Bilsteins front and rear. I have a 2002 Mustang Gt Conv. What spring rates am i looking at for a good ride don't want to stiff or to soft. plus i am carrying about 100lbs in audio equipment in the trunk.
01-10-04, 10:27 AM
Get the bilsteins found on '03 cobra coupes. Best bang for the buck and already valved for our realitive body weight.
Darren M's daily driven Mod'd Y2k GT
Mods to date on an otherwise stock GT.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride! - Email Thought for the day.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
