Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Race Tech
Reload this Page ~CrankShaft HELP~
Reply
(#1 (permalink))
Old
billy408stroker's Avatar
~CrankShaft HELP~ - 01-08-04, 08:51 PM
Does anyone know where any pic's are located' or how to remove a crankshaft in a 351 windsor' without taking off the heads or taking out the pistons??? I have been building Stroker & None Stroker Engines for a long time but never needed to remove a crankshaft because of a real oil seal leak! I have a brand new engine that im having to Install a Crankshaft repair sleeve' Probe Industries sent me. Some of the 427 stroker kits had a little undersized crank' where the seal runs. They said the best way to fix the leak was to install a Crankshaft repair sleeve. I have never had a rear oil seal leak in the 26 years i have been building motors....Just wondered if the crank would come out fairly easy without taking out the pistons' or the heads. I have the crankshaft repair sleeve and a new 2 pc seal' just looked it over today ' and looked like u could push about 4 pistons down & and turn the crank a little and work wit the other pistons & do it ok.... thanks....
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
