Go Back   Mustang Forums at StangNet > Mustang Forums > 2005+ (S-197) Mustang > 2005+ Talk
Reload this Page What details have you noticed on the 2005 V8 Stang?
Reply
(#1 (permalink))
Old
351CJ's Avatar
Official Member
What details have you noticed on the 2005 V8 Stang? - 01-11-04, 08:27 PM
I've been looking over the high res. photos and corral photos and I've noticed a large # of detail changes to the 2005 V8 Mustang. That is beyond the obvious things like "the mufflers are in the back".
Here are some of the things I've picked up, what else have the rest of you seen?
1. The intake plenum is really high and there is huge empty space below it. It looks like you can cook your dinner in there on the way home or keep your take out pizza warm in there.
2. The cone air filter is gone. In its place is a HUGE panel air filter and a HUGE intake air box.
3. There are only 2 cats.
4. The O2 sensors go into the cats not into the H pipe after the cats.
5. The first 02 sensor on the driver's side screws into the exhaust manifold.
6. Those sweeping exhuast manifold make it look like aftermarket shorties will be a total waste of money.
7. The oil filter is right at the front of the engine, maybe we'll be able to change the filter w/o spilling oil over the steering rack and cross member.
8. There are shock tower braces in the engine bay.
9. The front springs are up on the struts and not on the lower control arms.
10. There is not a traditional U-joint where the driveshaft meets the differential and there is some sort of flex coupling at the 2 piece driveshaft junction.
11. The engine oil drain plug is at the very rear of the oil pan. Looks like it we'll be sure to get all the oil out of the pan when the front wheels are up on ramps.
12. The electrical fuse / relay box in the engine compartment is HUGE. Must be a lot of electronics in it.
13. It's filled with gold (long life) coolant.
(#2 (permalink))
Old
01-11-04, 08:38 PM
Yep, those are interesting things. Hehe.... the front suspension is a MacPherson strut setup.... and I assume 2 cats is a good thing.... and the shorty thing is probably true, too... looks like damn good manifolds... and I think the air gap in the intake (if there is one? I haven't looked that closely), is probably to make the intake charge cooler, which means more power
-Michael
2004 Chevrolet Colorado Crew Cab
2005 Toyota Matrix Xr
past vehicles:
-'95 Camaro Z28, '00 Camaro Z28,
'98 VW Passat 1.8 turbo, '88 VW Golf GTI 16v,
'98 Z71 4x4 truck, '90 Kawasaki EX500 (Ninja), etc.
future vehicles:
'05-08 Mustang GT ?, '09 Camaro ?, '04-06 GTO ?
(#3 (permalink))
Old
Mach428's Avatar
Official Member
01-11-04, 08:45 PM
I get the feeling the production will not have 2 cats. I have no information to back this up from any source but my gut feeling is the production verson will have 4 just like the current mustangs. I think the reson for two cats and no resonators was for demonstration and marketing purposes. Someone please tell me i'm wrong.
2004 Mach 1
Best E/T 13.38 @ 106
60FT 2.24
Magnaflow Catted X w/Magnapacks
Steeda Tri-Ax
(#4 (permalink))
Old
tylers65's Avatar
I've got your tool right here!
01-11-04, 08:48 PM
Quote:
You're wrong
Goodbye Hybrid, Hello Toaster
2008 Scion xB
(#5 (permalink))
Old
Zinc001's Avatar
Registered User
01-11-04, 09:16 PM
It also looks like the mass air and the air temp sensor are part of the air filter housing.
(#6 (permalink))
Old
351CJ's Avatar
Official Member
01-12-04, 04:22 PM
Quote:
I'd say you're right in this, most of the newer Ford's are set up that way.
(#7 (permalink))
Old
Official Member
01-12-04, 05:19 PM
I would say with the technology of todays cats, and them being placed so close to the exhaust manifold, I think the new Stang will only have 2. Only time will tell though.
97 Black GT
Check out Horseplay Performance, your source for AZ Mustang parts.
Power Mods - Mac O/R H, Mac Catback, ported stock plenum, Steeda pullies, PI intake manifold, K&N, PI Cams
Misc Mods - D&D UCA's & LCA's, UPR Shifter, 4.10's
Best 1/4mi - 14.001 @ 98.9mph w/2.009 60ft
Dyno numbers - 229rwhp 280rwtq (before cams)
(#8 (permalink))
Old
siege's Avatar
Official Member
01-12-04, 05:20 PM
am I wrong, or are the bolts for the headers on the top and bottom of each tube? seems like it might be a PITA to swap headers or replace a gasket
Jason
86 Mustang GT with 87-93 LX body/interior, smoked headlights, 79-82 tails, E-303 cam, cold air intake, MAC equal length headers, offroad h-pipe, Borla XS turbos w/dumps, aluminum driveshaft, centerforce dual friction clutch, aluminum radiator, flexlite black magic fan, generic wannabe pro5.0, no smog pump, crane valve springs, ghetto PS delete, UPR quadrant/extreme fw adjuster.
best ET: 15.335@91.153mph w/ 2.314 60ft... yeah, I suck
coming soon..nothing, I got no monies!
(#9 (permalink))
Old
Eos's Avatar
Eos Eos is offline
Oh Heather Oh yeah... I want your pink taco
01-12-04, 05:23 PM
How do you think the new stang will sound, do you think it will sound better then the current stangs?
Who the hell invited you?
(#10 (permalink))
Old
siege's Avatar
Official Member
01-12-04, 05:31 PM
from the video of the detroit unveiling, it sounds pretty nice
Jason
(#11 (permalink))
Old
351CJ's Avatar
Official Member
01-12-04, 06:14 PM
Quote:
Yes, it certainly looks like the exhaust manifold studs are straight up & down (directly above and below the exhuast ports) instead of turned at about a 20 degree angle as on past 2V & 4V heads.
Good observation.
The exhuast ports also look D shaped to me instead of fully round. I'd have to see them side by side, but the 3V head exhaust ports look larger than on the 2V heads.
(#12 (permalink))
Old
RodStang's Avatar
01-12-04, 06:24 PM
There is a fake gas cap on the back of the car. Does that mean it will also simulate an explosion if someone rear-ends it?
(#13 (permalink))
Old
SVTdriver's Avatar
01-12-04, 06:59 PM
Yes you will hear a boom when you get hit.
2006 GT - Intake Cover, MGW e-brake cover, MGW radio knob, Redline leather console cover, Corsa axleback, Steeda shifter, GT500 rear spoiler, Painted interior bits, Cobra rear emblem. More things on order
Audi A4 1.8 Turbo. Blackened Taillights. Otherwise stock.
Cobra - Dead on the side of the road.
1966 Fastback project - Gone but not forgotten
(#14 (permalink))
Old
351CJ's Avatar
Official Member
01-12-04, 08:27 PM
Quote:
Thank you for finally making me learn my lesson. I will NEVER again attempt to have a serious discussion on StangNet..
By the way, how many of you have noticed that all those beautiful photos that Ford has provided of the insides of the 2005 Mustang, the suspension, steering, rear axle, overhead view of the engine, exhuast, suspension, etc. and even the engine images are not photos of real parts. They are solid model CAD renderings.
(#15 (permalink))
Old
ThRippeR's Avatar
Official Member
01-12-04, 08:31 PM
To be honest about that, renderings provide a more clear vision of what is being made. I think actual photos will follow, but I don't mind just seeing the architecture.
(#16 (permalink))
Old
tylers65's Avatar
01-12-04, 08:31 PM
I knew most were, but I seriously thought that a few of the interior pics looked real.
Some people are damned good at CAD.
2008 Scion xB
(#17 (permalink))
Old
01-12-04, 10:42 PM
Uhm... I've noticed that there seems to be a power retractable antenna for the radio... heh.. yep.. that's about it...
1998 Mustang - Gone.
1993 Capri XR2 - Gone.
1989 Audi 100 Quattro - Gone.
2000 Buick Regal GS - BOOST!
(#18 (permalink))
Old
Official Member
01-12-04, 11:22 PM
Its not power retractable, its a fixed antenna.
On show cars, they just remove it (same with photo shots)
(#19 (permalink))
Old
siege's Avatar
Official Member
01-12-04, 11:33 PM
Good observation.
they used to be at a 20 degree angle? damn, I'm used to mine being straight across
Jason
(#20 (permalink))
Old
BLK91GT's Avatar
01-13-04, 07:12 AM
no room in the rear for a really wide tire without it sticking out of the fender
the rear shock is way towards the outside and the factory wheels have the offset of a front wheel drive car
2002 Dodge Dakota Quad-Cab 4.7L V8
SVTOA-Memphis
2001 Mustang COBRA (Traded)
1991 Mustang GT (Sold)
1999 Mustang GT (Traded)
2000 Mustang GT (Ex-Wife's Traded)
2003 Mustang GT Convertible (Ex-Wife's ride)
(#21 (permalink))
Old
01-13-04, 01:11 PM
Quote:
-Michael
If Ford uses their best current technology then the headers should be pretty good. Jackson Racing said the headers on the SVT Focus are so good that no aftermarket version is required, even for supercharged applications.
(#22 (permalink))
Old
