Go Back   Mustang Forums at StangNet > Mustang Forums > Power Adder and Race Tech > Race Tech
Reload this Page 350 Rwhp with this combo????
Reply
(#1 (permalink))
Old
350 Rwhp with this combo???? - 01-17-04, 03:55 PM
I am wondering if its possible to hit 350 rwhp with this setup.
Fresh 302 .60 over Flat top pistons
Comp Xe274H Cam
66 289 heads 53cc chamber, ported, 1.94/1.6 valves, Roller Rockers
Edelbrock F4b Intake, Edelbrock 1406 Carb
Edelbrock 100 shot wet kit
Mac equal length Shorties, prochmaber mid pipe, pro dumps,
(#2 (permalink))
Old
50Dreamer's Avatar
01-18-04, 10:31 AM
Holy ***** .060 is a lot to take off if i remember correct. You could see some high heat from that. 350hp is possible with the combo but im thinking your gonna have problems with heat. Good luck though
(#3 (permalink))
Old
01-19-04, 01:09 AM
I didn tknow heat would be an issue is there anyway to help it?
(#4 (permalink))
Old
sldghmr's Avatar
Official Member
01-19-04, 03:03 PM
My understanding is that .060 over is as large as you can bore safely, before haveing serious problems. Hopefully one of the true engine gurus will spot this and reply about the possible power levels. My belief is that you should be able to surpass 350 w/the nitrous kit.
1995 Stalker GT 13.13 @104.17
Go: 150K mile stock short block, B303, TMoss lower, Comp Cams 1.7RR, Thumper heads, 80mm C&L MAF, BBK L/T ceramic headers, Dr. Gas O/R X-pipe, Flows, 3.55 gear, MAC lowers, BBK 1.5 springs & poly cups, poly offset rack bushings, MSD 6al, MSD Blaster, McCarville tune-up kit.
Show: Cervini Stalker body kit, Cobra R/SVO hood(pin-on), 3 pod A-pillar w/Nordskog digital guages, Cobra headlights and diamond clear sides.
Mantra: What's Life without Friction
(#5 (permalink))
Old
12sec67's Avatar
Official Member
01-19-04, 05:50 PM
you'll be under carbed without the nitrous....at least step to the 750 edelbrock. see sig i'm pullin approx 310rwhp through an AOD.
SEE MY CAR IN PHR MAG! http://www.popularhotrodding.com/fea...ang/index.html
TURBOCHARGED- T-70 -1967 mustang coupe
Roller CHP 347 9.7:1
ford X-CAM,Canfield heads,vic jr intake,proform 750
AOD w/ 3000stall
CURRIE 9" 3.50's
17 x 7's/17 x 11's - ET STREETs 26x 10.5s
1/8 mile 7.10 @ 98.75 Barona drags... 7.2 @100.4 barona best mph
Classic Performance & Repair/ www.CPRstreetmachines.com
info@cprstreetmachines.com
(#6 (permalink))
Old
87gtboy1984's Avatar
01-19-04, 11:31 PM
Quote:
no your not j/k tbird i'd say listen to what 12sec67 says... i get ran by him all the time and he knows what he's talking about
solid axle, and now some n2o
Whatever
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
IS 350 RWHP realistic with ??? 2002BLGT 4.6 Tech 27 01-18-04 01:39 PM
350 rwhp NA from a 96 2v? BlackVert 4.6 Tech 30 01-13-04 06:50 AM
Is this a good combo for 300 rwhp or more?! NC5.0 5.0 Tech 4 01-12-04 10:22 PM
