Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Reload this Page New Help Guys w/Mach 1
Reply
(#1 (permalink))
Old
Question Need Help Guys w/Mach 1 - 04-06-04, 06:30 PM
I just purchased a Mach 1 and thrilled with it. Before I had a 03 GT and this Mach 1 gets up and goes. Anyway, I need dyno specs for exhaust systems on a stock Mach 1 and I mean from headers to mufflers. I wanna get magnaflow, no cat X-pipe, and headers (not sure long, short, or mid). Any suggestions will help. Again, looking for horsepower and torque because i ve heard some people lost power or torque. Also, is 10 to 1 compression too much for a blower or other power adders.
Ben
(#2 (permalink))
Old
Angus's Avatar
04-07-04, 07:41 AM
Quote:
Ben;
Congrats on your new Mach 1! I hope you enjoy it as much as I do mine.
Here's my stock '03 Mach 1 dyno & stock w/K&N Air Filter:
Here is my car with the Bassani '03 Cobra Catted X-Pipe/Magnaflow Cat-Back/K&N Aircharger Intake system/4.30 gears - I still have the stock cast-iron exhaust manifolds on the car:
There's certainly more power left with the addition of either some good shorty, mid-length or full-length headers.
FWIW, I'm probably going with the Bassani Mid-Lengths due to their ease of install & good power gains while not losing ground clearance.
The Mach 1's 10:1 CR & 4V heads LOVE Nitrous - big gains in power & lower ET's can be the result of a small 75 - 100 shot.
A good tune would be mandatory for long-term safety & reliability.
As far as blowers go, the stock Hyper-U-Craptic pistons & powdered rods are the weakest link in all the 4V motors (with the exception of the '03/'04 Cobras).
If the engine is under boost & experiences detonation, you've got a pretty good chance of breaking something unfortunately.
Again, with a good tune that's checked regularly, a blower motor should last a good long time if you don't get greedy with the boost, use good fuel & check the tune for changes on a regular basis.
Good luck with whatever you decide to do!
'03 DSG Mach 1
297.7 rwhp/309.0 rwtq
Best ET/MPH/60': 12.844 @ 107.75 mph (1.77 60')
Bassani '03 Cobra Catted X-Pipe,
Magnaflow Catback, Steeda Aluminum LCA's, K&N Aircharger, BFG Drag Radials,
4.30 gears/Eaton 31-spline posi/31-spline Superior axles/TA 8.8 Girdle, Raptor shift light,
MM Full-Length SF's/Clutch Quadrant/Firewall Adjuster & Adjustable Clutch Pedal.
(#3 (permalink))
Old
94BossGT's Avatar
04-10-04, 06:20 PM
Check out what others are modding for exhaust,etc...over at the Mach 1 Owner's club...@ www.mach1registry.com
Link for mods...
http://www.mach1registry.org/forums/...p?s=&forumid=9
David Wagner
Founder/Admin
http://www.Mach1Registry.com
dave@mach1registry.com
www.mach1performance.org Parts & Accessories
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
