Quote:
Originally Posted by JTGrant
plat plugs are junk. They are only for longevity, actually a copper plug is better for performance.
It all depends on your setup. Plat. plugs are designed for longevity yes, but the motors are designed to run to the specs of the plug, resistance, heat range, stock gap, etc. If you have a built motor, and
need a colder plug, thats one thing, to be honest though, the stock plug for a 4.0 is an AGSF24P, which is the EXACT plug as the AP5143, so unless the ink on the plug barrel is worth 20+HP, someones been misinformed.
The '05 motor might actually be running the AGSF24FM which is a finewire platinum, in which case it would be a downgrade to switch over to the ap5143. In certain cases it is true, copper can be better for performance, but in a mild V6 set to run platinum, with no major engine mods, your better off to stay with what you have.
