Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 Talk
Reload this Page Engine shaking
Reply
(#1 (permalink))
Old
Official Member
Engine shaking - 04-17-05, 07:59 AM
long story - short - 94 gt stock
Engine shake came on quick.
Done so far....
*Changed fuel filter, plugs, wires, cap, rotor, pvc valve
*clean MAF
*clean K&N air filter
*looked and did not find any vacumn line leaks
*Hook up two cans injector cleaner to fuel rails and ran it thru - improved 80%
*ran two cans injector thru two tanks of gas - no improvement.
*pulled injectors, soaked them in cleaner, replaced one that was not allowing fuel through. Car ran the best it has ever run with no engine shake and lots of new found pickup for 30 miles. then shake came back slowly until it is now shaking so bad I am afraid to drive it.
what next - clean fuel tank, blow out fuel lines, reclean injectors?
Any ideas or suggestions welcome.
1994 Red GT Vert. 116,000 Miles, B&M T-Handle Shifter, 2 Chamber Vtech IV Mufflers, Air Silencer Removed, K&N Air, PIAA Xtreme White Bulbs, Pioneer CD, CDC Light Bar, CDC Directional Mirrors, 1996 GT 5 Star Ranger Rims, Billet Pedals-door lock knobs- A/C knobs-headlight knob.
(#2 (permalink))
Old
droptopford 5 0's Avatar
Official Member
05-04-05, 11:52 PM
Done so far....
*clean MAF
what kind of shake is it, rpm specific, at idle, all rpms, with the clutch in or out... whatsup?
(#3 (permalink))
Old
cavscout371's Avatar
Official Member
05-05-05, 05:47 AM
has the balancer ever been replaced?
TJ
1995 GT Black
Trick Flow Track Heat H/C/I, TF 1.7 rockers, C&L 76mm maf + pipe, 30lb inj., Mac 1 3/4 L/T's, 3in Cust. O/R Exh., flowmasters, Crane Ignition, 255 lph pump, and Compucar NOS kit.
Waiting to be puchased: AFPR, Gears!, and a laundry list of other crap I cant afford.
(#4 (permalink))
Old
Redline_351R's Avatar
05-06-05, 06:00 AM
I bet your harmonic ballancer is shot.
1994 SVT Cobra #42 of 5009/ 95 Cobra R drivetrain
Performance- AFR 185 Heads/ Trick Flow R Intake/FTI Camshaft/BBK 75MM TB/ DBX 97MM Meter/Tremec 3550
Chassis- 4 Point Cage/Welded Subframes
Exhaust- Magnapack catback/ Bassani X pipe w/cats/Roush Headers
Misc- FMS 3.73/ Centerforce clutch/Moser 31 Spline axles/FMS 31 spline differential
340 RWHP/390 FT LBS TQ (old combo numbers)
Best ET to date (10-5-07) 12.884@107.61 1.808 60 FT (New combo times coming soon)
FS:24LB INJECTORS
(#5 (permalink))
Old
Official Member
Fixed it - 05-06-05, 09:16 AM
The whole engine and trans would shake like hell - all rpms - for a day to two and then stop. heres why -
It was the harmonic balancer. The hard rubber weight inside the metal cover was loose and spinning. Sometimes when I shut the car offf and then back on the rubber part would stop at the right spot, be in balance, and the car would not shake anymore. Drove me me nuts trying to find this one. Thanks for your help!
(#6 (permalink))
Old
05-06-05, 09:31 AM
what are you going to get for a new ballancer?
FS:24LB INJECTORS
(#7 (permalink))
Old
Official Member
balancer - 05-06-05, 09:54 AM
The guy who did it for me (brother-in-laws friend) who is a mechanic put a stock balancer back on there from Ford. The car has 170,000 on it now and runs great being 99% stock. I want to keep it that way until the engine goes and then I will build a bigger engine from the block up. Just trying to keep the car in good shape so I can have a fun winter tear down and rebuild someday. With all the tuneup and tweaking done trying to fix this problem the car jumps when I touch the pedal now. It never used to do that.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
>>>>TECH ARTICLES<<<< Red_LX 2.3L (N/A & Turbo) Tech 93 09-11-08 03:29 PM
my cobra engine died BADLY and will not start...is my engine blown 98yellsvtcobra SVT Tech 15 11-30-04 02:47 PM
Is my engine blow more than likely if It dies and makes grinding noises? 98yellsvtcobra 4.6 Tech 5 10-17-04 11:47 PM
wiring questions for my swap while I build the engine tonight, help ASAP!! stackz 2.3L (N/A & Turbo) Tech 1 04-23-04 11:24 PM
