Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Shine Shop
Reload this Page wet sanding question
Reply
(#1 (permalink))
Old
Official Member
wet sanding question - 05-04-05, 09:40 AM
I posted in the other area that my car is being wet sanded. It is an 04 white GT and it had rust colored specs on the paint when it was transported via rail. Ford is taking care of it. They say they are wetsanding and buffing it, taking about 4 days to do. When they say buffing, does that mean polishing?
My real question is, what should I do with it when I get it home, put a sealant and wax on it? I already have Meguiar's NXT for it.
Thanks.
(#2 (permalink))
Old
Official Member
05-04-05, 09:02 PM
Make sure it looks brand new, I wouldn't put any shine stuff on it. It should already, If anything, I would wash it, and just let it dry, to see if the clear coat is still ok.
Http://members.cardomain.com/chrisbudl1
97 pacific green cobra
removed silencer, K&N filter, a/t catback,5%rear20%sides5%windshield strip. 4:10 gears, tokico illumina s\s, H&R SS springs, MM cc plates, summit 8.8 diff cover. Steeda x2's, and bumpsteer, mac offroad h pipe, custom aluminum drive shaft, saleen replica wheels, and toyo t1's tires 295/35/18 rear, clear diamond side markers, brembo rotors with hawk HPS pads, spring isolaters, MGW BLUE!
(#3 (permalink))
Old
05-04-05, 09:12 PM
If I were you I would wax it to protect the paint. When they wetsand the car it will also get rid of any wax that you may have put on it so I would wax it just to have a coat of wax on it to protect the paint. Just my opinion.
(#4 (permalink))
Old
Official Member
05-08-05, 09:52 PM
clear coat looked fine. I washed it, clay barred it, washed it again, polished it with Meguiar's Step 2 polish, and applied two coats of Meguiar's NXT wax. Pix are in 'Talk' section....
(#5 (permalink))
Old
05-16-05, 08:55 AM
Thanks.
Wetsanding?? No way should they be wetsanding a OEM paint job! Sure it can be done but the factory clear is so thin that they may have just shortened the life of your paint. If they remove to much from the top coat then they mess around with the UV absorbers which in turn leads to premature clear coat failure.
Ford should of known this and instead gave it an acid wash...or just clayed it. Claying will not remove the metal particles but it will at least shave them off. An acid wash would remove them and this is what SHOULD of been done. I would be causing a huge fuss if that were my car.
Anthony
(#6 (permalink))
Old
HardmanGT's Avatar
05-16-05, 10:41 AM
Anthony
Clay will absolutely remove the metal. Giving an acid bath is bad for your trim. Most companies don't even make the acid bath/ industrial fallout remover anymore.
Never should have let the dealership touch the car. Better off to take it to a pro and send them the bill.
-Jeremy My Car Domain Page
FOR SALE PM me for details
1989 GT 5 speed
best run 13.3 @ 104
311rwhp 337rwtq
(#7 (permalink))
Old
05-16-05, 12:40 PM
Hardman,
I agree with you to a point. A pro should of handled this. Clay though will NOT remove the imbedded particles. The metals will "bloom" rust again even if clayed (this though depends largely on the degree of contamination) as the clay will only remove the protruding particles.
Acid washes are safe IF instructions are followed. Auto Internationals ABC system is used by Ford and many other manufacturers so this is why I am amazed that this Ford dealer chose wetsanding over an acid wash.
Thanks for your input,
Anthony
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Question for Dodgestang (GT Valance owners) grantur01 Classic Tech 8 06-11-04 07:12 AM
Valve Seals question?? Lex 2.3L (N/A & Turbo) Tech 1 06-08-04 12:37 PM
Pipes and H/C/I question question of the night sweet93hatch 5.0 Tech 9 05-02-04 12:14 PM
Gears/mileage question jermy82 94-95 Tech 7 03-20-04 07:18 AM
NX question AmishRebel Power Adders 0 03-02-04 12:37 PM
