Quote:
Originally Posted by Infinity02Zinc
I think it's kind of a precursor to products like Zaino. The stuff actually works pretty good- it just doesn't last long. Of course, as easy as it works, you don't mind doing it more often.
Apples and Oranges. Zaino is a synthetic polymer and Zymol is a natural Wax. Zymol prides themselves on using natural ingredients in their products.
There is a wide range of Zymol products from their Zymol Cleaner wax which is packaged and distributed by Turtle Wax up to their expensive Estate waxes that require a home mortgage to purchase.
If you bought Zymol at an auto parts store it is likely the cleaner wax. I used it for a long time and I found it to be durable. It does have a few drawbacks though, it will stain black trim white and if you apply too much it is a bear to remove. Knowing those limitations though it is a good product. I do believe the Zymol has discontinued this as the result of a dispute with Turtle Wax. You will probably still be able to find it on store shelves though as I have seen it locally.
http://www.zymol.com/onestp2.htm
I also have some of the more expensive Zymol products like their Zymol Creame and it is a breeze to use but, as others have said durability is an issue. The people Zymol targets their high end products to don't really care about durability as their products are usually used on garage queens.
http://www.zymol.com/crecar2.htm
