Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Shine Shop
Reload this Page still need help cleaning polished wheels!
Reply
(#1 (permalink))
Old
9646gt's Avatar
Official Member
still need help cleaning polished wheels! - 06-18-05, 11:01 AM
Well the mothers power ball took alot of tarnish and such off the wheels but I am still not stisfied with the look as they are kinda dull..what else can I try? There must be some well kept detailer scret that someone can lend out to a fellow stangnet member in need! Anyone?
US Air Force Eielson AFB, Alaska
Sold-Will be missed-
Black on Black 1996 Mustang GT 4.6L
170k miles strong!
T-45 5-Speed w/ Hurst shifter
Polished 17x9 Cobra rims
4.10 Gears
MAC CAI
O/R 2.5" Mid pipe
Flowmaster 40 Series mufflers w/ no tail pipes
(#2 (permalink))
Old
stang22's Avatar
Official Member
06-18-05, 11:35 AM
This is what I do that works the best for me:
I use a 2.5" polishing arbor on a 2500rpm drill. I smear the Mother's polish, (or whatever polish you use) all over the wheel and then go to town. I let the drill do the work and it always comes out looking like new. There is a tool for every job.
Tim
(#3 (permalink))
Old
Curse's Avatar
Official Member
06-18-05, 03:03 PM
http://metalgloss.com/index.cfm?id=1...rowse&pageid=1
This stuff works awesome.
Vic
89 GT
TFS TW heads, TFS stage 1 cam, Tmoss ported Typhoon intake, Scorpion 1.6 RRs, 70mm MAF/70mm TB, Kirban AFPR, 255lph, U/D pulleys, electric fan, Fluidyne rad, A/C delete, MSD Digital 6, wires, distributor & coil, BBK shortys, x-pipe, flowmasters, Strange struts, 3.73s, SVO diff girdle, SFC, Pro 5.0, Ford cable, UPR FWA/quadrant,King Cobra clutch, aluminum D/S, etc...
M/T ET Drags and DynoTune wet nitrous kit.Still on 19lbs injectors
(#4 (permalink))
Old
Official Member
06-21-05, 01:32 AM
If you go to sears they have these compound bars with different strength levels. Use a tougher one like a gray and then go to white for a final polish. You can also buy a set of polishing wheels for your drill. The bars and wheels should cost you around $15. Make sure you use a different wheel for each bar or they will mix the different compounds together and it will be hazy. If you do it correctly, they will BLING!. I had polished wheels that went through winter and looked like butt. My brother who does car resto's does this to his stainless and it looks like chrome. Turned out great. Took a while, but worth it in the end.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Getting Wheels Chromed or Polished Nagash01WS6 94-95 Tech 1 05-30-05 03:23 PM
Anyone know weight of polished factory wheels? Unsprung weight... coladin 2005+ GT Tech 8 05-19-05 10:10 AM
