Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page WOT TPS value off for my Tweecer?
Reply
(#1 (permalink))
Old
zenboy99's Avatar
WOT TPS value off for my Tweecer? - 01-06-06, 06:27 PM
I have my tps sensor set at 0.990 volts but I'm still reading 4.75 volts at WOT wich the Tweecer isn't recognizing as WOT in Calcon. Am I doing something wrong? I've drilled out the TPS sensor for a wider range.
-Chad
2006 Mercury Milan V6 Premier
1995 Mustang GT 185,000 miles
-TW heads/Systemax intake/FTI custom cam
-Boltons, stock shortblock, G-Force T5
-Tweecer tuned by me
330rwhp @5750rpm 12.32@111mph
Winter mods: New FTI cam, Beehive valve springs, Ti retainers, 4.30 gears
(#2 (permalink))
Old
mo_dingo's Avatar
Official Member
01-06-06, 07:17 PM
fwiw I was reading 4.66V at wot...maybe it's too high???? i dunno
Quote:
When devils will the blackest sins put on,
They do suggest at first with heavenly shows. - Othello
Scott - '95 GT - Triple Black Vert
DSS 306 forged and balanced short block
Trick Flow Track Heat H/C/I
Tweecer R/T, C&L MAF
FRPP lifters/RR's/30lb. Inj's/3.73's
BBK Headers, Magnaflow C/B, Bassani O/R X-Pipe
MGW Shifter and other goodies!!!!
2006 Yamaha Blue YZFR6
http://www.myspace.com/scottydoesntknooow
How to install gears!!!
(#3 (permalink))
Old
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
01-06-06, 08:32 PM
The puter should recognize WOT at high3 volts or low 4 volts (Grady, et al, will know). I only know the fox spec, which is 3.7 volts.
Good luck.
(#4 (permalink))
Old
final5-0's Avatar
Official Member
01-06-06, 08:56 PM
Hey Chad
I show about 4.73
Don't think its anything to get bothered about
BUT ................
Seems to me, if you were looking for a higher reading, you might wanna check to see if the tb blade is all the way to a 90 degree setting at WOT.
Might be able to turn the key on, motor off, and work the tb while looking at the data log
Already told you more than I know about it
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#5 (permalink))
Old
HISSIN50's Avatar
01-07-06, 01:31 AM
Grady, does the puter need to see such a high voltage to realize one is at WOT? I would not have guessed it had to be so high. I bet some TPS's dont even quite reach that threshold.
Or is that what you folks max out your TPS reading at?
(#6 (permalink))
Old
zenboy99's Avatar
01-07-06, 06:41 AM
I took the intake tract off and the throttle blade is going a tad past 90 degrees. When I put my foot to the floor the car goes into open loop, but its not registering as WOT in calcon.
When you guys are in calcon does your WOT light go green?
-Chad
(#7 (permalink))
Old
final5-0's Avatar
Official Member
01-07-06, 06:48 AM
Not exactly sure JT
Like you, I suspect if one's value was a bit + or - from the value that Chad & myself see .........................
Everything would be OK
Kind of the same thing as the closed throttle deal
.99 is not that important as there is a range that is acceptable because the pcm sees anywhere in that range as closed
Grady
Tweecer Tuned
293hp 322tq
(#8 (permalink))
Old
Don 95Vert's Avatar
01-07-06, 12:05 PM
The T4M0 - stock has the TP for WOT set to 642 AD counts - which converts to 3.13296v, so you are fine - even though the blade is not fully open, the EEC 'thinks' that it should go to open loop fuel.
Don
2006 Mustang GT
1994 Turbo Lightning SCT Tuned to 502/635
LaSota Racing Technologies Website
don@lasotaracing.com
(#9 (permalink))
Old
HISSIN50's Avatar
01-07-06, 12:30 PM
Quote:
Don
Thanks Don - that was the threshold I was curious about.
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
And once again an idle problem!!! nxb88 5.0 Tech 15 11-01-05 09:52 PM
What is the WOT voltage on the TPS?? accidentprone86 5.0 Tech 6 09-12-05 12:20 AM
Pulled Codes what do they mean snoboardcore 5.0 Tech 3 04-07-05 03:05 PM
wot tps voltage? 90lxnotch 5.0 Tech 7 04-10-04 05:34 PM
WOT on TPS sensor is at what voltage mytight95 94-95 Tech 2 02-21-04 09:45 PM
