Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page Can I put on a MAF meter calibrated for 24# injectors without using a Tweecer?
Notices
Reply
(#1 (permalink))
Old
Official Member
Can I put on a MAF meter calibrated for 24# injectors without using a Tweecer? - 01-17-06, 07:45 AM
Straight forward question. Let's say I have 24# injectors and a MAF calibrated for 24# injectors. Do I need a tweecer??
94 GT Vert, pro-motion Gforce T-5, 414 c.i., 401rwhp, 432rwtq [OLD NUMBERS]. NO POWER ADDED. Upper and Lower TQ box welds, eibach pros, panhard bar, lca's, kenny brown "T" subframes[welded], tokico blues.
www.rnhperformance.com
"The car that sent me to the bar."
36# PERFECTLY matched injectors used for 1000 miles only! MAKE OFFER!! FLOWMASTER 50 Series DELTA Flow 4 sale!! Almost new! $120 new...$60each 50% off?
(#2 (permalink))
Old
01-17-06, 07:56 AM
if the MAF is calibrated to the injector size, you do not need a tweecer. the car should run fine.
The list.....
1991 Mustang GT - Totalled
1994 Mustang GT - Sold
2003 Mustang Cobra - Sold
1994 Mustang GT - Sold Again
2006 Mustang GT - Daily Driver
2008 Honda S2000 - The new toy
(#3 (permalink))
Old
Official Member
01-17-06, 08:12 AM
Thanks man!
(#4 (permalink))
Old
BlackVert's Avatar
Official Member
01-17-06, 08:21 AM
you don't NEED a tweecer, but ...
you are still "fooling" the computer by letting in more air than the computer thinks is coming in. the extra air is compensated for by the injectors, so it should run fine.
most of the decisions the computer makes are dependent on the perceived load. it uses the amount of air reported by the maf to determine the load.
in your case, the actual load will be higher than the load the computer calculates, so its decisions (like spark advance and target a/f ratio) will be less accurate. specifically, a/f could be targeted too low and spark may be advanced too far (because the computer thinks there is less load then there really is). this could result in detonation.
that said, the difference in load is probably not enough to cause real problems, epsecially if you have an afpr. then if you do get detonation in the higher load ranges, you can up the pressure to get around it (but then you are probably too rich down low).
1995 Black Mustang GT Vert ... '71 block 410W, 10.27:1 CR, AFR 205s, AOD, FR500s, Toyo R-888s, and a couple other things
1967 Black Fairlane GTA Vert ... 390FE, C6, totally stock
- Chris (curlbud-stangnet@yahoo.com) ... CAI for sale cheap ...
(#5 (permalink))
Old
Don 95Vert's Avatar
01-17-06, 09:23 AM
Quote:
Originally Posted by BlackVert
it uses the amount of air reported by the maf to determine the load... in your case, the actual load will be higher than the load the computer calculates, so its decisions (like spark advance and target a/f ratio) will be less accurate.
This is about 99% correct - the 1% wrong part is with a calibrated MAF, load will be lower than it should be - and at lower loads the spark is higher. With an NA car with 24# injectors - as stated, it probably won't be an issue, because at 90% load the spark (without considering adders/subtractors) is 25* - with a 24# calibration load would be reduced to about 71% spark would be about 27-28* - still pretty safe for a NA car. Although with a 94-95's propensity for pinging this COULD be an issue. This also assumes the ability to get to 90% load, which it probably would not do - so the spark might be still higher.
Don
2006 Mustang GT
1994 Turbo Lightning SCT Tuned to 502/635
LaSota Racing Technologies Website
don@lasotaracing.com
(#6 (permalink))
Old
BlackVert's Avatar
Official Member
01-17-06, 11:12 AM
Quote:
Originally Posted by Don 95Vert
... load will be lower than it should be ...
that is what i said, just the other way around, isn't it? i said "the actual load will be higher than the load the computer calculates", which means the computer's load will be lower than it should be.
maybe i'm not following you.
(#7 (permalink))
Old
Don 95Vert's Avatar
01-17-06, 12:48 PM
Lost in translation.. LOL!! I see what you meant!
Don
2006 Mustang GT
(#8 (permalink))
Old
BlackVert's Avatar
Official Member
01-17-06, 01:14 PM
Don
(#9 (permalink))
Old
Official Member
01-17-06, 08:41 PM
Going with a custom tune BTW. Tweecer is up for grabs. It is a base but can be sent in for an upgrade. Great for someone who likes to tune it themselves. I went custom chip.
(#10 (permalink))
Old
zkillrr's Avatar
Official Member
01-25-06, 12:20 AM
Well guys i bought a pro m about 2years ago cal for 24# injectors and it took some of my low end power and I don't feel it up top either. I wonder is it b/c i don't have a ajustable feul pressure reg. Any comments.
Edelbrock upper & lower intake, Mac longtube headers
shorty h-pipe, 24lb injectors, U/D pulleys, Pro M mass
air, 65mm throttle body, cold air kit, 3.73 gears, Steeda Tri-Ax shifter, Eibach springs, Drags out back
(1994 GT)
(#11 (permalink))
Old
final5-0's Avatar
Official Member
01-25-06, 12:46 AM
Quote:
Is it possible your heated wires in the maf electronics need to be cleaned.
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#12 (permalink))
Old
zkillrr's Avatar
Official Member
01-25-06, 12:55 AM
Its funny you say that b/c it was like that the first day i put it on. I had to look at the box to make sure they sent me the right one . All the #s match up but who to say the didn't put it in the wrong box. How do i clean it and could it have come dirty?
(1994 GT)
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
42 lb injectors, stock maf 96snakebite 4.6 Tech 2 11-28-05 05:50 PM
42 lb injectors - what MAF? 94gsl5.0 94-95 Tech 12 08-31-05 12:37 PM
Pro-M Racing Univer MAF calibrated for 42lb fuel injectors Vellines V6 Tech 2 04-07-04 08:35 AM
Are there any cars than use a MAF meter for 24lb injectors that will bolt on my car? BlackFox5.0 5.0 Tech 8 12-23-03 10:37 PM
