Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page tweecer users please help
Notices
Reply
(#1 (permalink))
Old
AUcobra94's Avatar
Official Member
tweecer users please help - 01-17-06, 09:43 AM
I datalogged the car last night and its around 12:1 air fuel at idle. My question is what table or function do I change for idle and normal driving? The second question is for WOT I think the table is WOT_fuel_multiplier-v-RPM, is that table right? In this table(WOT fuel mult-v-RPM) the RPM settings are all at 0 and the fuel mult settings are all at 1. Should I add the rpms? thanks Dan
PS I live in Auburn Alabama and if there is anyone close to there that would be willing to help me or just talk to me on the phone about it,I shure would appriciate it.
94 Cobra(white): trackheat intake, crane 2031, steeda tri-ax, 76mm C&L, 65mm TB(BBK), 355 gears, mac LT, mac O/RH-pipe, 2-Chamber Flows, msd 9A
Best time na: 1/4-13.481 mph-102.26
80 shot nitrous: 1/4-12.823 mph-111.55
(#2 (permalink))
Old
WhiteDevil's Avatar
Official Member
01-17-06, 10:00 AM
To adjust your WOT Air fuel ratio the best be would be the top part of your MAF curve or what i use which is the Stabilized_OL_Fuel or something like that in the tables section.
Parts for sale!! Low prices! Check it out!
Click Here http://forums.stangnet.com/showthrea...44#post7518944
(#3 (permalink))
Old
broken_joke's Avatar
Official Member
01-17-06, 01:27 PM
i had a situation like that a few weeks ago. i had my min_inj_pulsewidth to high. i dropped the pulsewidth down to .0003 after reading some threads. now the computer controls the pulsewidths and i'm not rich at idle anymore.
351w(357), afr 205's, spyder intake, comp xfi cam, 42#'s, pro m 85mm, 90mm accufab, 3:55's, j4j1 tune
http://videos.streetfire.net/categor...10D67FCFC5.htm
totalled!
new ride-96 cobra
4.10's, 6speed, magnaflow exhaust,tweecer tune
(#4 (permalink))
Old
final5-0's Avatar
Official Member
01-17-06, 04:31 PM
Quote:
Was the 12 to 1 value from your wide band or was this a lambse value that you saw in your dlogs?
Here are a couple things you could do here Dan to change idle fuel conditions
1) You can work with your inj low slope value
higher value will lean things out
lower value will fatten things up
2) You can work with your maf curve idle point and maybe one before & one after that point. Up the airflow value to fatten and Lower the value to lean.
btw, if you saw a lambse value of 12 to 1 at idle then you are too lean. The pcm is commanding a rich ratio to try and compensate.
As John said above, the stabilized fuel table is what most 94-95 guys I know about use for WOT fuel adjustments.
You see WOT_fuel_multiplier-v-RPM used by the fox guys alot. I'm not saying that won't work but I don't recall ever seeing anybody with our cars use it.
Just in case you may not know and for safetys sake of your combo ..........
You need to work with a wide band for WOT final fuel ratio adjustment.
Lambse values seen in your dlogs are not accurate and can not be trusted for this part of tuning.
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#5 (permalink))
Old
blksn955.o's Avatar
01-17-06, 05:09 PM
IIRC the only time I have heard/seen about the fuel v rpm table being used on our 94-95's was with boost as a way to make it richer (over the commanded stablized OL table) on our 94-95's.
I realy dont see the need though as the fuel stablized OL is preaty good...but maybe the safty for the boost may be what they are looking for??? I am not boosted so I dont realy get into that side of tuning.
my stable
Black 1994 GT: DSS pro bullet 306, tfs stage1, thumper ported gt40heads/tmoss explorer intake , compucar wet kit,TwEECerR/T, 99+ GT front brake swap, bullit springs, msd 6al, 98gt maf, 24#inj., pullies, 3.73's, K&N, ARE TTII's for the street and Pro stars for the track, and some other stuff.
http://www.cardomain.com/ride/642232
(#6 (permalink))
Old
AUcobra94's Avatar
Official Member
01-17-06, 06:07 PM
Thanks everybody. I am using the lambse, and the real concern is the car being extremely rich at idle. Ill play with the fuel stabilized at OL and see if I can lean it out. I knew the lambse were not accurate but do they usually read more lean or rich? They read 11:1 at WOT at around 5000 rpm. So I can use the Fuel_stabilized_OL table to change air fuel from Ilde through WOT?
(#7 (permalink))
Old
blksn955.o's Avatar
01-17-06, 06:22 PM
For idle you will want to look at your MAF curve and inj. slope/breakpoint/offset.
It would also be a good idea to post a detailed list of mods...MAF, Inj. size, processor file your using, Fuel Press. setting.
IF your running a 30lb inj. or larger you might want to look at some of final5-0's posts in a search about running forced CL at idle to keep the eec from "drifting" over time.
But first you should focus on MAF and inj... Eec Annalizer will help get that down quickly if you dont have that program already.
E.A. should be bought the same day the tweecerR/T is bought if you ask me.
my stable
(#8 (permalink))
Old
AUcobra94's Avatar
Official Member
01-17-06, 07:35 PM
thanks blksn955.o, I think I found the annalizer on final 50's web page. I will buy one, does it annalize the datalog and make suggestions? thanks again everybody
(#9 (permalink))
Old
blksn955.o's Avatar
01-17-06, 07:48 PM
yes, you load a DL into it and it "crunches" the data. The help files and Clint the guy who made it are very helpfull.
You can download the program for free and look at it, but in order for the calculations to work you have to purchase a reg. code to activate the program fully.
my stable
(#10 (permalink))
Old
final5-0's Avatar
Official Member
01-17-06, 11:08 PM
Dan
If you are seeing lambse values of 12 to 1 at idle you are lean.
At idle you are in Closed Loop conditions. The Lambse value of 12 to 1 is what the pcm is asking for or commanding to try and achieve a ratio of 14.7 to 1
The fact that Lambse is lower means the pcm is asking for a fatter ratio.
You also can look at your KAMRF's which is the adaptive strategy or a fuel trim if you will. If everything was right on the money at idle, you would see the K's at a value of 1.00
K's > 1.00 = adaptive adding fuel to compensate for lean conditions
K's < 1.00 = adaptive pulliing fuel to compensate for fat conditions
btw, K's only come into play during CL conditions.
I'm not trying to be a hard case kind of guy Dan
but
fuel tables is one of the places you can do some damage and I really am wanting to make sure you see this from the perspective of how the pcm deals with fuel.
Lambse values seen in your dlogs is NOT your af ratio
Lambse values seen in the fuel tables is NOT necessarily your af ratio
If you had a wide band
AND
You adjusted your fuel table and maf curve where they matched your wide band values
Then
You could use the Lambse values in the fuel table to choose your final af ratio
Still one more way to look at what we are talking about here is like this
Values in the fuel table are what the pcm is going to try and command.
If you got different maf, inj's, etc ....................
Things could be off in the tune ................
Even though you see 11.7 in the fuel table ...................
That don't mean 11.7 is what you are gonna get......................
Only a wide band is gonna let you know what you really got during WOT.
If you are too lean at WOT ... damage could happen
Grady
Tweecer Tuned
293hp 322tq
(#11 (permalink))
Old
Black95GTS's Avatar
Official Member
01-18-06, 07:20 AM
To the original poster, from my experience: One of the hardest things that I had to get into my head when TwEECing our computers is how they determine load. On a FOX, RPM is used to determine load. Pretty easy. But on an SN95, air flow is. Its an entirely different philosophy and one of the reasons our computers are so damn tricky.
This is why the FOX guys use the fuel vs. RPM table, and why its not as useful for us except in special circumstances like the one listed above.
Adam
How to count to 8: 1-3-7-2-6-5-4-8
SOLD: 1995 Black/Black Mustang GTS
TFS Intake, MAC Shorty Headers, BBK o/r X, American Thunders, MSD 45kV coils, FMS 9mm wires, CAI, Edelbrock 255lph, TwEECer ver. 1.30, subframes, FMS 65 mm tb, 4.10s out back, ASP Underdrive Pullies, FMS HD clutch, Steeda tri-ax.
Quote:
Originally Posted by juiced_94gt
...was thinking about a gas saver but then i said "playaz dont worry about gas prices"
(#12 (permalink))
Old
AUcobra94's Avatar
Official Member
01-18-06, 10:13 AM
thanks guys
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Tweecer users - need your help!! iluv95stangs 94-95 Tech 18 08-14-05 10:43 PM
TwEECer RT users -- Help For My 125 shot setup KDK1988GT 5.0 Tech 0 08-10-05 12:13 PM
TwEECer users... 88 Fox GT 5.0 Tech 4 12-01-04 05:05 PM
PMS - TwEECer users in here 2Blown98 4.6 Tech 2 11-25-04 02:21 PM
