Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page Effects of humidity on MAF transfer/function
Reply
(#1 (permalink))
Old
zenboy99's Avatar
Question Effects of humidity on MAF transfer/function - 01-28-06, 12:40 PM
I've never really thought about this, but I thought it would be worthy of discussion. I just drove around for an hour in the rain and got a good data log, I'm curious to see how it compares to the datalog on a cool dry winter day.
My co-workers husband is an atmospheric scientist and I'm going to ask him a few questions. I believe a given volume of air will have the same oxygen content no matter what the humidity of that air is? Same with altitude, a given volume of air will have the same oxygen content at low pressure and high pressure, however pressure will effect how air is being pumped in and out of the engine. So how would a higher moisture content effect the voltage of my MAF? Water has a better specific heat (heat transfer ability) than air so I would think the voltage should change faster. But if the oxygen content is the same for a given volume of air being introduced the MAF shouldn't be effected.
The scientist in me is thinking that with a higher humidity an extra amount of moisture/water is being introduced into the combustion chamber. Wouldn't this lower combustion temps and effect the exhaust leaving the chamber?
It would be interesting to take two new mustangs, one driven in a cool winter desert and the other driven in Seattle and see how the EEC adapts to those conditions.
Just some thoughts, any opinions or comments are welcome.
-Chad
2006 Mercury Milan V6 Premier
1995 Mustang GT 185,000 miles
-TW heads/Systemax intake/FTI custom cam
-Boltons, stock shortblock, G-Force T5
-Tweecer tuned by me
330rwhp @5750rpm 12.32@111mph
Winter mods: New FTI cam, Beehive valve springs, Ti retainers, 4.30 gears
(#2 (permalink))
Old
blksn955.o's Avatar
01-28-06, 02:42 PM
The maf takes into account those things.
There are tables I believe that deal with humidity...I have the names but I dont remember off the top of my head.
I asked the same question or one related to it when I first started using the tweecer.
my stable
Black 1994 GT: DSS pro bullet 306, tfs stage1, thumper ported gt40heads/tmoss explorer intake , compucar wet kit,TwEECerR/T, 99+ GT front brake swap, bullit springs, msd 6al, 98gt maf, 24#inj., pullies, 3.73's, K&N, ARE TTII's for the street and Pro stars for the track, and some other stuff.
http://www.cardomain.com/ride/642232
(#3 (permalink))
Old
final5-0's Avatar
Official Member
01-28-06, 04:38 PM
People will say moisture or temp will not effect things cause the maf has the ability to compensate.
Once upon a time I would have agreed.
Still do, for the most part.
however
Two years ago at the end of Summer I had been working with my final WOT fuel ratio.
Had lots of data from a time period that the temps were usually about the same. These dlogs were from the afternoons after I got off work.
Early one Sat morning I made a couple dlogs back to back with driving conditions no different from all the others. The only change I had made to the file for both of those test passes was a slight change to only one maf point.
Much to my suprise when I looked at those two dlogs
The ratio for the entire OL or WOT part of the curve had dropped about .25 of 1 point.
Nothing but the temps had changed. In the earlier dlogs taken from the afternoons the temps had been in the high 80. That Sat morning the temps had dropped to the mid 60's.
Makes one think a bit .................. don't it
then again
Hard Data Don't Lie
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
MAF unplugged=Torque-y ride..Plugged in...Slow..? chris kelvin 4.6 Tech 9 12-24-05 07:34 AM
11.0 AFR @ 30psi on dyno daemion_AF 5.0 Tech 6 11-24-05 05:07 PM
Engine running like crap...pulled codes. 89stangalang 5.0 Tech 6 09-14-05 11:25 AM
Pulled Codes Synned 5.0 Tech 6 08-05-05 07:47 PM
mass air conversion stangfist420 5.0 Tech 4 07-14-05 11:47 PM
