Drivability issues can be so frustrating
You may be able to play around with things like, tb blade stop screw, isc air bleed, fuel pressure, timing, and the like for a more stable idle
but
doing all the above and even more may not give you much relief.
I've spent a lot of time looking into drivability issues and it is my firm belief that when talking about this subject, it just ain't a cut & dry kinda deal.
Even when you have access to all options in the pcm, drivability issues can be quite the challenge from time to time.
I've worked with other Self Tuners who have combos similar to mine. On more than one occasion, I've seen each of us have to deal with things in the pcm the other did not necessarily have to mess with to obtain decent drivability.
I've seen some of the chip burners offer a reburn at a reduced rate if needed. Maybe if something like that is available, it might help.
Like the others above have said, use what mechanical adjustments you have available to you and see how much improvement you can obtain.
Here is a little tip that may help with your mechanical adjustments
Make only one change at a time and reset the pcm.
Wait a few days before changing anything else.
That amount of time should give the pcm's adaptive strategy a chance to stabilize enough to the point you should be able to tell if any improvement is being made.
If you need to make another change, reset the pcm & wait again to see the results of your change.
Good Luck finding that ...... ever elusive stable idle
Grady
