| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
Official Member
Ok...Load or Loadx -
02-06-06, 01:32 AM
At idle load is 17xxx and loadx is 27xxx. I've researched and found out load should be at or around 20%. Also, the readings states that Loadx is really Load :? . Which Load do I look for to be around 20%? Oh yeah I also read that you can adjust this by changing the size of the motor but not the best way. The correct way is the Sea level load scaling. Which load do I look at to be around 20%.
Thanks
Engine: (10:1 CR) AFR 165 heads,Performer RPM,
75mm MAF,BBK70mm TB, MAC CAI, lunati cam,Crane gold 1.6rrs
Electronics: TwEECer R/T-1.30v(J4J1),MSD 6AL, wires/coil,lunar gauges,Innovative LMA-2 wideband 02
Suspension/Chassis: MM Coilover (F/R), MM LCA/UCA, '03 Cobra LCA, global west subframe, STB
Suport System: Walbro GSS340, Fluidyne, 3.73s, Yellow top battery B&M ripper
Looks:ARE Torque Thrust IIs, 17x11s (315/35) , 17x9.5(275/40)-Nitto 555s
Official Member
02-06-06, 09:05 AM
Al
As I understand it, the Load Switch Scalar is what determines if you use Load or LoadX or as some have called it, Load%.
Scalar = 0 use LoadX
Scalar = 1 or 2 use Load
A couple of stock cal file Load Switch examples are:
t4m0 = 2
j4j1 = 0
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
Official Member
02-06-06, 05:55 PM
Quote:
Originally Posted by final5-0
Al
t4m0 = 2
j4j1 = 0
Grady
Got it very simple and straight to the point. I like that. Now Loadx is at 27% at idle. Can I just up the CID in the scalar a little to correct or should I do the Sea Level Load.
Thanks Grady
Official Member
02-06-06, 06:15 PM
Quote:
Thanks Grady
I've not had any experience with either of your Q's
I currently idle at around 25% load and even that is a little bit high
I don't think that value is off enough to make me wanna fool with all that other stuff. I have looked into the load scaling thing a couple times but just blew it off.
I've already got my fuel & spark tables to my liking
so
I just ain't gonna mess with it
Have you already bumped up your cubic inch size to 306?
Grady
Tweecer Tuned
293hp 322tq
Official Member
02-07-06, 07:43 AM
so
Grady
Yes I have it at 306. But I will check to make sure I did not change the settings.
Thanks
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
