Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page I'm in market for WB 02s
Reply
(#1 (permalink))
Old
Methodical's Avatar
Official Member
Wink I'm in market for WB 02s - 02-19-06, 02:09 AM
I want to purchase a WB o2s but need your help. Please give suggestions on which unit to buy and why, the approximate cost and the vendor information. Is the WB difficult to install?
Thanks
Al
Engine: (10:1 CR) AFR 165 heads,Performer RPM,
75mm MAF,BBK70mm TB, MAC CAI, lunati cam,Crane gold 1.6rrs
Electronics: TwEECer R/T-1.30v(J4J1),MSD 6AL, wires/coil,lunar gauges,Innovative LMA-2 wideband 02
Suspension/Chassis: MM Coilover (F/R), MM LCA/UCA, '03 Cobra LCA, global west subframe, STB
Suport System: Walbro GSS340, Fluidyne, 3.73s, Yellow top battery B&M ripper
Looks:ARE Torque Thrust IIs, 17x11s (315/35) , 17x9.5(275/40)-Nitto 555s
(#2 (permalink))
Old
CManT1914's Avatar
Official Member
02-19-06, 07:26 AM
Innovative LC-1 from eBay!! It costs right at $200 IIRC.
(#3 (permalink))
Old
VibrantRedGT's Avatar
"Official SN Penguin Smacker"
02-19-06, 08:08 AM
I'm also in the market for a WB. I want the one with its own external screen.
Car has been sold.
Mods and Pics here:
1994 GT / 347 Stroker / 64,000 miles / 1 of 344 Made
http://www.mustangworks.com/cgi-bin/...splay.cgi?1682
VibrantRedGT@stangnet.com
(#4 (permalink))
Old
final5-0's Avatar
Official Member
02-19-06, 09:24 AM
Al
I use a FJO that is now around 4 years old. It has none of the features like wb's of today but gets the job done. I've not really paid a lot of attention to how things have changed but I can offer some ovservations I've seen over the years.
A good while back some on the Tweecer site said they believed the dual hook up of digital display and Tweecer was causing inaccurate readings.
There also was some talk that the file in the Stkr/Data directory with the ext of dbf could be inaccurate. This file contains the values of volt to afr definitions. You will see files for several wb choices if you look.
I did a little research and came to the conclusion that mine was reading about 1/4 of a point lean. I never looked at my digital display anyway as it was always kept it under the seat so I discoed it for more accuracy.
As for hook up. I would want it to be included in my dlogs without a doubt.
You can use the wb analog output as an input to the pcm's egr input as one method of hook up. You then simply select egr as one of your Cal Con payloads to dlog.
You can also buy an interface called Data Q for hook up. I don't know much more than that but details are available at the Tweecer site.
I have seen threads from time to time where talk is about getting the correct file or how to build a file like I was talking about above to work correctly with a paticular wb.
Thats just about all I can think of that might help Al but let me know if you need anything else and I'll see what I can do.
Joe
I don't have much knowledge about the PMS
but
it is growing thanks to this forum!
IIRC, most PMS users do not data log.
I've always wondered how PMS peeps would get the data from the PMS & wb in sync or how they look at the PMS unit and wb all at the same time.
ANYWAY
However it is done, I would think if the wb is stand alone from the PMS, you would want one that has the ability to capture data other than afr like rpm and such.
I have seen you post up a dislike for having to carry around a laptop before. Seems like your desire for more data is gonna push you in that direction.
Here is this thread that offers a device with six channels if you did not see it.
wideband and fuel map tuning.
Let us know what you decide Joe as I would like to learn more about how this all works with the PMS.
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#5 (permalink))
Old
final5-0's Avatar
Official Member
02-19-06, 09:38 AM
Quote:
Thanks
Al
I forgot to say this in my above post Al.
A wb with a lot of options like data logging and the like is not really needed since you got the Tweecer's dlog capabilities.
You might be able to save some money ... who knows?
Grady
Tweecer Tuned
293hp 322tq
(#6 (permalink))
Old
02-19-06, 11:44 AM
Grady datalogging with the PMS requires interaq upgrade for $269. The WB can sync with the PMS as well. A WB with it's own box and external screen is all I'm looking for. I'm not looking to sync the two.
Car has been sold.
Mods and Pics here:
(#7 (permalink))
Old
final5-0's Avatar
Official Member
02-19-06, 12:37 PM
I got the idea now Joe.
Basically you want it as stand alone
I've seen a lot of guys on the Tweecer site say they like the Innovative like Chris talked about above.
Pretty sure some of our members are using it as well.
Grady
Tweecer Tuned
293hp 322tq
(#8 (permalink))
Old
Methodical's Avatar
Official Member
02-20-06, 07:43 AM
Thanks fellas. I will do more research on the matter.
(#9 (permalink))
Old
BlackVert's Avatar
Official Member
02-21-06, 10:53 PM
Can the LC-1 be hooked up to be displayed in the TwEECer's CalCon? I don't need a screen if I can use the TwEECer for it, and I'd rather have it integrated with the datalog anyway.
1995 Black Mustang GT Vert ... '71 block 410W, 10.27:1 CR, AFR 205s, AOD, FR500s, Toyo R-888s, and a couple other things
1967 Black Fairlane GTA Vert ... 390FE, C6, totally stock
- Chris (curlbud-stangnet@yahoo.com) ... CAI for sale cheap ...
(#10 (permalink))
Old
final5-0's Avatar
Official Member
02-21-06, 11:17 PM
Quote:
Just got back from the Tweecer site
Tons of threads about the LC-1 over there
Grady
Tweecer Tuned
293hp 322tq
(#11 (permalink))
Old
Rootus's Avatar
Officially Addicted
02-22-06, 07:49 AM
My favorite WB is the Dynojet Wideband Commander. AFAIK it's the only one with an 2 1/16" Autometer analog gauge. The nice thing about that is that you can integrate it seamlessly with more aftermarket gauges. It has the ability to light a warning light (on the gauge, or an external one if you want) based on RPM/AFR/throttle position. And it can datalog standalone, and download to a laptop via USB later. Or real time.
Dave
(#12 (permalink))
Old
final5-0's Avatar
Official Member
02-22-06, 08:34 AM
Another wb that seems to be used a good bit by folks is the PLX.
I saw it come up a good bit on our forum and on the Tweecer site.
I must say the wb Dave talks about has a lot of features.
Lots of choices these days
means
More and more decisions these days
Grady
Tweecer Tuned
293hp 322tq
(#13 (permalink))
Old
BlackVert's Avatar
Official Member
02-22-06, 09:41 AM
do any production cars use wideband o2s? i'm just wondering if it would be possible to scavange one off a junkyard car ...
(#14 (permalink))
Old
zenboy99's Avatar
02-22-06, 09:56 AM
Yes, a few VW's do, they use the same Bosch sensor as most of the kits are using. A few of my local friends have made their own wideband from that sensor. I can try to get more info for you from them. They're all running BMW's and imports though.
I'm running the PLX-300, I got it for ~$290 shipped NIB on E-bay. The install went pretty well with some help from people on here.
-Chad
2006 Mercury Milan V6 Premier
1995 Mustang GT 185,000 miles
-TW heads/Systemax intake/FTI custom cam
-Boltons, stock shortblock, G-Force T5
-Tweecer tuned by me
330rwhp @5750rpm 12.32@111mph
Winter mods: New FTI cam, Beehive valve springs, Ti retainers, 4.30 gears
(#15 (permalink))
Old
blk9450's Avatar
02-22-06, 09:59 AM
i got an lm-1 for sale for $275 with like 500 miles. aem has a good one out too
**RIP**94 exv6, 5.0 5spd, tp-38 turbo, deltagate, c&l73, 30#s, paxton fmu, turboxs bov, eibach prokit, ported e7s, ported lower, 255lph walbro, 3.73's,
http://www.cardomain.com/ride/2198841
(#16 (permalink))
Old
BlackVert's Avatar
Official Member
02-22-06, 10:11 AM
that would be great, thanks
(#17 (permalink))
Old
blk9450's Avatar
02-22-06, 10:53 AM
i tried to do that a while ago but the diy wideband community has died out and i get no responses from anyone.
(#18 (permalink))
Old
BlackVert's Avatar
Official Member
02-22-06, 11:35 AM
i just need the sensor itself, it can be hooked up to a tweecer. i'd like to get it for less than $200 if possible
(#19 (permalink))
Old
blk9450's Avatar
02-22-06, 12:00 PM
no thats not how a wideband works
(#20 (permalink))
Old
BlackVert's Avatar
Official Member
02-22-06, 12:26 PM
