I will answer this but it needs to be moved to the II discussion area. You can put in a rear from a 65-66, they are supposedly the same legnth. Or since you have an 8in in your car you can call any axle company that makes 28 spline axles..ie Moser...and order new ones. Here are the axle legnths: right side 29 7/8....... Left side 25 13/16. The 65-66 axles are a 1/4 in longer on each if you want to replace just axles,then change shoes to the ranger (from 9x1 3/4 to 9x1 1/2 and you can use the ranger drum. One of the guys in the group has put an 8.8 in from a fox body but had to modify it to fit. hope this helps
