Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page Tweecer Newbie in Desperate Need of Help!
Notices
Reply
(#1 (permalink))
Old
Angry Tweecer Newbie in Desperate Need of Help! - 03-09-06, 11:48 PM
Well Guys first off ANY Help is greatly appreciated... I finally finished rebuilding my beast about 1yr ago and still dont have a good tune on it. It has even been to 2 performance shops and they cant get a good tune on it... I have a tweecer RT and do have some log files if anyone whats to take a look on a base X3Z computer... First questions in the data logging I did yesterday I noticed that one of my O2 sensors was getting a way different reading and logic tells me they should be close to the same so I dont know whats wrong there... Anyway here are the details with engine: 347stroker, 75mm mass air proM calabraited for 30ilb injectors, I have FMS 30ib injectors, Stock fuel system with regulator set a 40lb, trickflow twisted wedge fully proted and polished along with trickflow intake track heat also port matched & polished, MSD ignition FMS wires, stock distributer new cap, msd blaster coil, timming set 10degree base... Longtube's with off road x pipe. Trick Flow Stage II Cam Specs: 224int/232ExtDuration, .542int/563ExtLift, Cam lift .339/.352, 112lobe. Computer X3Z car will run and start on stock tune idles good. Not responsive at all on throttle sometimes back fires if i get on it hard with stock tune... Any other questions let me know any help is greatly appreciated like I said im NEW at this so take it easy on me.. Oh TPS .998 im sure I still forgot something..
(#2 (permalink))
Old
Black95GTS's Avatar
Official Member
03-10-06, 11:45 AM
Well like I replied in the post next to yours... get an aftermarket fuel pump. You just added a bunch of parts that will flow a ton more air but no parts that will flow a corresponding amount of fuel.
I would suggest a 255lph high flow fuel pump. You'll never be able to tune it in without the appropriate hardware necessary to achieve a good a/f ratio.
Adam
How to count to 8: 1-3-7-2-6-5-4-8
SOLD: 1995 Black/Black Mustang GTS
TFS Intake, MAC Shorty Headers, BBK o/r X, American Thunders, MSD 45kV coils, FMS 9mm wires, CAI, Edelbrock 255lph, TwEECer ver. 1.30, subframes, FMS 65 mm tb, 4.10s out back, ASP Underdrive Pullies, FMS HD clutch, Steeda tri-ax.
Quote:
Originally Posted by juiced_94gt
...was thinking about a gas saver but then i said "playaz dont worry about gas prices"
(#3 (permalink))
Old
vristang's Avatar
Official Member
Another noobie! - 03-10-06, 01:00 PM
Welcome to Stangnet!
I am the guy that spoke to you on the "other" site.
I didn't even think about the fuel pump before.
IF the fuel pump is the problem you should see that the O2 is close until a certain rpm/load. At least that is what I think.
jason
(#4 (permalink))
Old
Zero Signal's Avatar
Official Member
03-10-06, 02:30 PM
Can you find a way that we can download your tune? See if you can email to me. Chances are, if your banks are reading way different, you have a problem with the .CCF
First read the EEC and save that file and tune off that instead. Also make sure you have the right strategy selected. If not, you will have all kinds of nasty problems.
John
New Plan (as of 7/31/08): Buy a running stock motor just to get the stang running again.
Current down time: 3 years, 2 months.
Currently:
- 347 locally built, sitting in the garage
Dream Parts:
- AFR Comp 185 Heads
- FTI Custom Cam
- Tick Flow Track Heat Intake
- PMS System
(#5 (permalink))
Old
I Have a 255 fuel pump... - 03-12-06, 03:54 PM
The car has a 255 fuel pump and the car seems to be running very rich plenty of fuel maybe not enough air????
Thanks
Chris
(#6 (permalink))
Old
final5-0's Avatar
Official Member
03-12-06, 10:37 PM
The first thing I would do is see why you get different readings on the O2's.
Do you think you might have an exhaust leak?
Or maybe a bad O2? You always could switch them for a simple test.
You must know everything mechanical is OK before your start to tune or you're wasting your time.
What is the deal with the back fires?
I can't stress enough the fact you could do some damage here and the first priority is to get some decent Closed Loop drivng conditions. At this point in time, WOT conditions should take a back seat here.
Do you show the K's to be active during idle and if so, what are the values?
Have you set your new cubic inch scalar?
What is your load at idle?
That ought to provide enough info to help the members get started to help you if you answer each question.
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#7 (permalink))
Old
Angry Data Loggin Issues NOW??? - 03-17-06, 02:45 PM
Well I was wondering if anyone could tell me why when I try to data log it works however all the numbers im getting are all crazy like everything is reading but reading inncorrectly. Any insight would be greatly appreciated..
Thanks
Chris
(#8 (permalink))
Old
vristang's Avatar
Official Member
03-17-06, 11:27 PM
I am surely not the most experienced tweecer here, but all I can think of is that the calibration file does not match the strategy.
That's the best I've got.
(#9 (permalink))
Old
50Dreamer's Avatar
03-17-06, 11:38 PM
Get a F.A.S.T system...seriously your gonna fight with it forever...Or an SCT MAS and tune...
(#10 (permalink))
Old
final5-0's Avatar
Official Member
03-18-06, 07:27 AM
Quote:
Would you mind sharing why you feel that way
Grady
Tweecer Tuned
293hp 322tq
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
TwEECer Tuning Manual BlueOvalStangGT 94-95 5.0 Tuning 17 10-14-07 04:40 PM
help me decide... tweecer R/T, PMS, or DFI? 1105 94-95 Tech 21 07-13-06 06:02 PM
TWEECER NEWBIE HERE! Need help fine tuning: Idle & Bucking problem mustanggt94 94-95 Tech 11 06-08-05 04:31 PM
I'm a newbie with the Tweecer, need some help defacto_pr 94-95 Tech 4 10-30-04 04:15 PM
I'm a newbie with the Tweecer, need some help defacto_pr Power Adders 0 10-30-04 09:48 AM
