| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
wheres the hp -
03-10-06, 06:04 AM
i have a 95 gt w a dss pro bullet with tw heads a track heat intake, long tubes, 10.5:1 comp ratio and all the bolts ons and the best i can get is 284rwhp, 304 ft/lbs torque. seems kinda low to me? any sugestions? Oh it also has a b 31 cam
65 289 mustang- running
95 lx- sold to dad
98 gt- wrecked
97 cobra
cold air
off road h
flows
94 gt
dss pro bullet 306
10:1 comp
tfs heads
tfs track heat intake
anderson b 31 cam
pro m maf
30# injectors
c&l power pipe
70 mm tb
tremec 3550
griffin radiator
msd dist, 6Al, and coil
mac long tubes
off road h
flows
Official Member
03-10-06, 06:16 AM
I'm sure you have but did you get the car dyno tuned? If not that may release a s***load of power.
2002 Mustang GT (automatic)
K&N FIPK CAI
Dragon Performance 75mm TB/Upper Plenum
SLP longtube Headers
SLP Catted X-pipe
SLP LoudmouthII Cat Back
03-10-06, 09:19 AM
yes i did have the car tuned w a sct chip when i had it dynoed.....cost me $500
befor the tune it was at 272rwh. i kinda wish i had just bought a pms for 800!
but then i would have still to pay to have it dynoed. the guy that tuned it is a reputable tuner in my area and he said they were good #s but from what im seeing on here it really isnt that great. i bought the car with all the upgrades done to it...im kinda thinking maybee the cam lobes are worn or something
95 lx- sold to dad
98 gt- wrecked
97 cobra
cold air
off road h
flows
94 gt
dss pro bullet 306
10:1 comp
tfs heads
anderson b 31 cam
pro m maf
30# injectors
c&l power pipe
70 mm tb
tremec 3550
griffin radiator
mac long tubes
off road h
flows
Official Member
03-10-06, 09:52 AM
i Don't know about any of that stuff so i can't really help ya.
K&N FIPK CAI
SLP Catted X-pipe
Official Member
03-10-06, 11:39 AM
Quote:
Well you didn't list an aftermarket fuel pump. And you need one deperately bad. I suggest that as the first step! Without additional fuel, there will be no additional power.
Adam
How to count to 8: 1-3-7-2-6-5-4-8
SOLD: 1995 Black/Black Mustang GTS
TFS Intake, MAC Shorty Headers, BBK o/r X, American Thunders, MSD 45kV coils, FMS 9mm wires, CAI, Edelbrock 255lph, TwEECer ver. 1.30, subframes, FMS 65 mm tb, 4.10s out back, ASP Underdrive Pullies, FMS HD clutch, Steeda tri-ax.
Quote:
Originally Posted by juiced_94gt
...was thinking about a gas saver but then i said "playaz dont worry about gas prices"
Official Member
03-10-06, 11:43 AM
Makes sense.
K&N FIPK CAI
SLP Catted X-pipe
03-10-06, 11:48 AM
From sim. combos the track heat seems to stick out to me as too big for that setup. I would see if someone can swap you a street heat upper and see if there is an improvement.
A fuel pump is also in need like said above.
with a tune I would think high 290-310 would be a good est. Your close though so not a real bad issue.
my stable
Black 1994 GT: DSS pro bullet 306, tfs stage1, thumper ported gt40heads/tmoss explorer intake , compucar wet kit,TwEECerR/T, 99+ GT front brake swap, bullit springs, msd 6al, 98gt maf, 24#inj., pullies, 3.73's, K&N, ARE TTII's for the street and Pro stars for the track, and some other stuff.
http://www.cardomain.com/ride/642232
Official Member
03-10-06, 11:52 AM
hes already done a tune though.
K&N FIPK CAI
SLP Catted X-pipe
Official Member
03-10-06, 01:59 PM
Hmmm I don't know about that. I believe, but I'm not positive, that the AFM cam ideally spins to 62-6300 RPMS.
As the owner of a street heat, I can tell you from personal experience that it definately bottle necks at 5500. Leaving 7-800 RPMS on the table is  The second I get higher flowing heads and a cam I will be swapping to a track heat upper. The street heat is really only good for stock or MAYBE unworked GT-40 heads.
HP = (Trq * RPM) / 5252. All other things being equal, less RPM = less HP.
Adam
03-10-06, 03:48 PM
I have seen it with a few fox's. For whatever reason it just does not go well with the stock TW heads.
and I would say that street heat is better than a set of un-ported gt40's...by bit unless your saying the street heat is less of an intake than the gt40 intake...that is matched to the gt40 heads from Ford.
either way he is close...maybe its that the power he has is just what its going to put out.
my stable
Official Member
03-10-06, 04:02 PM
Sorry, I confused you... I meant that unless you are running stock heads or stock GT-40 heads, then you need a bigger intake then a street heat. Anything bigger then those two sets of heads will want to support higher revs then a street heat is good for.
The street heat is essentially a stock replacement intake. IMO. When combined into an HCI package, I personally feel that the street heat will leave power on the table.
You may ask, Adam, why did you buy the street heat then? Well, I would say that I plan to spray my car long before I do the cam and intake. My car won't see revving much past 5500 for at least a year.
Adam
Official Member
03-10-06, 04:25 PM
Even though it looks like your numbers should be a bit more
It could be many things and you may not have a prob at all
Was this possibly a Mustang Dyno?
Were the values SAE or actual?
Lets start with those two Q's
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
03-10-06, 04:47 PM
I believe the street heat is sold with the TFS package with the TW as a matched set.
and very good points Grady...that should have been the first question asked.
Dynos are good for A/F, and checking what setup/change makes more power at a given day on the same dyno. Take it to the track and see what it does...if you go and bust out a mid-high 12 or low...low 13 at like 107mph...I wouldnt care what a dyno said.
my stable
Official Member
03-10-06, 07:38 PM
Since you have said this
Have you ever thought about 1/4 mile results along these lines?
I feel many things can throw off dyno results from time to time.
however
I myself am no stranger to the 1/4 strip. I know all too well the driver can make soooooooo much difference when trying to compare one combo to another.
As a matter of fact, I myself feel I can get a better idea of what a combo is gonna do by dyno results rather than 1/4 mile results.
Let me just throw out two names that to me tell the whole story about how misleading 1/4 times can be:
Paul Riva
Jackie Chan
Comments anyone
Grady
Tweecer Tuned
293hp 322tq
03-10-06, 09:03 PM
both ways have variable issues that change.
I just think that the dyno can be mis-leading in that it takes away from the real world sort of speek. So does the track with say a diff. driver than the owner. If the owner cannot drive the car to its full...then whats the point if someone else gets say a 11 or 12 1/4 mile out of it when the driver who ownes it runs it in the mid 13's.
I am of the thinking that both Dyno and 1/4 used together...like getting the most out of a combo by seeing what makes the most as far as parts, tune, ect. at the dyno. As well as taking it to the track to see how well it puts it down and how the driver works with those things.
kinda like what good is a 500hp dyno run when you cut a 2.9 60ft and shift slow ending in a 1/4 time of 13.5.
Or
A car runs the owners goal of low 12's but the combo is on a poor tune that is going to blow up the engine on the 3rd pass while leaving power on the table.
my stable
Official Member
03-10-06, 09:27 PM
My guess is that it was a Mustang Dyno. Good point Grady.
Brad
03-13-06, 09:35 AM
thanks guys i spoke to the tuner over the weekend and he said they were great #S my 1/4 mi times are not that great though bc of my tires.....im only running 225!!!that is definitly my next mod!
95 lx- sold to dad
98 gt- wrecked
97 cobra
cold air
off road h
flows
94 gt
dss pro bullet 306
10:1 comp
tfs heads
anderson b 31 cam
pro m maf
30# injectors
c&l power pipe
70 mm tb
tremec 3550
griffin radiator
mac long tubes
off road h
flows
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
