Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page Tweecer datalogging issue
Reply
(#1 (permalink))
Old
jwalker's Avatar
Tweecer datalogging issue - 03-13-06, 06:36 AM
I cant seem to datalog. I followed the instructions in the Tweecer tuning manual listed in the first sticky. Nothing seems to happen. It says it is datalogging, but then the dash board never moves and when I try to read the data file, it just says its empty.
I just started using the Tweecer so I am new at this. I have used Cal Edit and it works fine.
Thanks,
Jeff
95 GT
12.07 @ 117.86
60' 1.79
tfs heads, st ht intake, 70mm TB, CAI, 30LB inj, 75 MAM, steeda #19 cam, Mac unequal shorties and X-pipe, FPR, 373 gears, tremec 3550,125 shot N20. Flip chip
(#2 (permalink))
Old
final5-0's Avatar
Official Member
03-13-06, 07:40 AM
Jeff
I'm not that familiar with your version of software but check to see if you have done these two things.
In Cal Edit you will find a place to select if you want to dlog or not
In Cal Edit you will need to build your payload of items to dlog
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#3 (permalink))
Old
jwalker's Avatar
03-13-06, 07:53 AM
yep did all of that.
My Cal Edit version is1.20B3
Do I need to phisically drive the car or can I just let it idle?
Jeff
95 GT
12.07 @ 117.86
60' 1.79
(#4 (permalink))
Old
final5-0's Avatar
Official Member
03-13-06, 08:05 AM
OK Jeff
1.20 I can relate to
You should see real time data at idle like rpm if that is one of your payload choices.
In your payload window you check 1 to 16 items and then click the Payload button and your choices will go blank.
Anytime you change your payload you will have to upload to the Tweecer. You may want to load to all 4 switch positions.
Grady
Tweecer Tuned
293hp 322tq
(#5 (permalink))
Old
jwalker's Avatar
03-13-06, 08:16 AM
Ok I will try this for all 4 positions and see if it works.
Thanks
Jeff
(#6 (permalink))
Old
jwalker's Avatar
03-13-06, 11:32 AM
didnt work. I tried it at lunch. I made all 4 switch positions the same settings and nothing. The button on the buttom of the Cal Can screen is green and I see it change to red when I hit "stop datalogging"
Not sure what this issue is.
Jeff
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
TwEECer Tuning Manual BlueOvalStangGT 94-95 5.0 Tuning 19 10-10-08 08:32 AM
help me decide... tweecer R/T, PMS, or DFI? 1105 94-95 Tech 21 07-13-06 06:02 PM
Tweecer datalogging - necessary? Monsterbishi 94-95 5.0 Tuning 19 03-09-06 09:14 PM
Basic Spark Info For Tweecer Noobs & ??? final5-0 94-95 Tech 3 10-17-05 09:08 PM
Tuning questions (chip vs. Tweecer and other ?'s) 5.0_GT_kid 94-95 Tech 45 07-14-05 06:21 PM
