Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Reload this Page Engine Displacement Question
Reply
(#1 (permalink))
Old
vristang's Avatar
Official Member
Engine Displacement Question - 03-15-06, 09:46 PM
I just need some confirmation...
The TwEECer manual was a little unclear what to do with engine displacement on stroker engines. The manual gives the impression that displacement changes are to be used as a global correction instead of changing the MAF and Injector settings.
Should the CID be adjusted with a stroker motor, when maf and injector settings are being changed as well?
Thanks
jason
(#2 (permalink))
Old
final5-0's Avatar
Official Member
03-15-06, 10:30 PM
Jason
Some have used size of the motor to tune. That method does in fact make a global change. It is all about the load.
For the most part, Tweecer tuners I have talked to feel it is best to tell the pcm all the actual facts about your combo.
Things like:
actual airflow for maf
actual inj size for slopes, offsets and other inj values
cubic inch motor size
throttle body air flow
idle air flow
etc
In your motor size scalar you are gonna be changing the load for all tables.
You would wanna do this before you start to change each table or work with scaling the load for the entire set of tables.
Grady
95GT, T5, AFR 165's, FTI Cam, Edel RPM,
30# inj, Mac LT's & Cat Pipe, 373's
Stock T/B, Maf, & Catback
Tweecer Tuned
293hp 322tq
Dyno Chart Idle Clip My Site
My Favorite Stangs Have
16 Pushrods & 3 Pedals
(#3 (permalink))
Old
vristang's Avatar
Official Member
03-15-06, 10:51 PM
Thanks for the response Grady.
I would think that telling the computer what is actually there would be better than trying to trick it.
Here is what I have changed tonight.
Function - Changed MAF Transfer to 73mm C&L w/ Green sample tube
Scalar - Changed Inj High/Low Slopes to 30.5/38.5 - (Low Slope = 1.26 * High Slope)
Scalar - Changed CID to 408
Scalar - Changed Idle in Neutral to 850
Scalar - Changed Thermactor Air Control Logic to Disabled
Scalar - Changed EGR System Type to Disabled
Scalar - Changed MAF Voltage Min = 0
Scalar - Changed MAF Voltage Max = 4.999
The maf transfer was included in CalEdit. I may have to order the Green Tube.
(C&L sucks with a tweecer!)
I'll go see if I can find
Idle air flow
and
Throttle body air flow
thanks again
jason
(#4 (permalink))
Old
final5-0's Avatar
Official Member
03-15-06, 11:23 PM
Jason
Don't forget to load in the offsets for your 30's as you now have offsets for 19's.
I can't be of much help with the C&L
Quite a few guys on the Tweecer site use them however
Grady
Tweecer Tuned
293hp 322tq
(#5 (permalink))
Old
vristang's Avatar
Official Member
03-16-06, 12:30 PM
So I found a formula for calculating the TB airflow, but it is based on the Maf at idle airflow. Where do I find the idle maf airflow number?
I held off on doing the injector offsets because the numbers I found that I should use (I think from the Tweecer manual), were significantly different than what was in the file, by an order of magnitude. I later found another source that gave me the same numbers though, so I think it is ok.
I'm not too worried about the C&L right now; I probably even have the right tube (green) sitting in the garage already.
Thanks for the advice Grady!
(#6 (permalink))
Old
final5-0's Avatar
Official Member
03-16-06, 12:45 PM
I gotta go in a min or two but
Here are a couple of sources
EEC Analyzer
and
http://eectuning.org/forums/viewforum.php?f=2
Be sure you stay with CBAZA as I think Fox stuff does not work correctly for us in this case.
Grady
Tweecer Tuned
293hp 322tq
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Kenne Bell VS Whipple Wsmatau 2005 - 2009 GT Tech 63 03-21-07 01:39 PM
Question about engine buildup Performance Red 4.6 Tech 2 12-19-05 04:51 PM
Fox newbie with an engine question andrewVA 5.0 Tech 4 12-05-05 10:56 AM
Question about this parts combo on my new engine 93RiceKillinGT 5.0 Tech 1 04-05-05 12:01 PM
newbie engine rebuild question. please advise? Mtay03 5.0 Tech 5 03-24-04 02:10 PM
