Like John said
Cal Edit can do it for you.
I think EEC Analyzer can as well.
The maf transfer is so critical because it is kinda like the foundation the whole tune is built upon.
Check your method of converting your sheet values with another method of converting.
You will then have two 30 point curves to compare.
You can even go to the maf files in your Cal Edit software for a third 30 point curve.
All three of them should be close
I can't tell you how much it would help you with your tuning eforts if you have a basic understanding of:
the maf
how maf companies utilize the cheat method
why an accurate curve is so important in a 94-95 Stang
and
HOW TO BUILD A 30 POINT CURVE FROM A FLOW SHEET
This link should tell you all the above
http://www.superstang.com/maf.htm
Hey Joe, think this one needs to be moved?
Grady
