Go Back   Mustang Forums at StangNet > Regional Forums > Southeast > SE Classifieds
Reload this Page Edelbrock Performer RPM Heads Small Block Ford 302 351 For Sale
Reply
(#1 (permalink))
Old
Edelbrock Performer RPM Heads Small Block Ford 302 351 For Sale - 03-25-06, 06:15 PM
I have a set of used Edelbrock Performer RPM aluminum cylinder heads (Part#: 60229) featuring 1.90” intake valves and 1.60” exhaust valves for small block Fords. Heads have been milled 0.030” by Central Florida Machine and Speed for (approximately) 55cc combustion chambers (standard 61cc). 1.90” intake valves perfect for stock pistons and will slightly raise compression for great Naturally-Aspirated power gains while staying on pump gas (2.02” optional valves require notched pistons for valve clearance). Springs have been upgraded (from FlowtechInduction.com) to accomodate extra lift for more aggressive camshafts (previously run with 0.556"/0.563" with 1.6 ratio). Heads come with "head bolt bushings" so that they may be installed with stock diameter head bolts. They have been on my motor for about 5,000 miles and made great power with a slightly modified setup. Have to sell because of switch to 331ci motor and in need of larger heads.
With SRP Flat Top forged piston (Part#: 138733), Ed Curtis Camshaft (specs available), 1.6 ratio Comp Pro Magnum Roller Rockers, Edelbrock Performer RPM upper and lower intake, and MAC 1 ¾” long tube headers, car made 322 hp to the wheels. Compression ratio slightly bumped to approx. 10.1 to 1 and 93 pump gas always run with no problems. Projected compression can be calculated easily online at http://www.turbofast.com.au/Tfcomp.html.
Asking $950 or best offer.
Picture of heads available at:
http://i45.photobucket.com/albums/f5...e699/Head1.jpg
More photos available by email upon request.
Andy Kelly
Orlando, FL
1986 Ford Mustang Coupe
302 ci TTI Single Turbo
(#2 (permalink))
Old
03-27-06, 02:10 PM
TTT
Andy Kelly
Orlando, FL
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Stock 351 Windsor Heads On Stock 302 ??? sporty4680 5.0 Tech 4 07-22-05 03:41 AM
Edelbrock Performer 5.0/5.8L Heads ike34 5.0 Tech 3 06-21-04 08:05 PM
Ordering Edelbrock Performer Heads next week! Rel 94-95 Tech 13 04-19-04 02:05 AM
Gran Turismo 4 Car list rudeone707 94-95 Tech 58 02-02-04 04:06 PM
Help! Edelbrock RPM heads vs. Trick flows mustangman_93 5.0 Tech 2 01-29-04 02:37 PM
