Go Back   Mustang Forums at StangNet > Regional Forums > Southeast > SE Classifieds
Reload this Page Lots of parts: rotors, wheels, ZEX, Remote Opt, GT40 Upper, injectors, MAF
Notices
Reply
(#1 (permalink))
Old
scarless's Avatar
Official Member
Lots of parts: rotors, wheels, ZEX, Remote Opt, GT40 Upper, injectors, MAF - 05-25-06, 10:56 AM
13" 94-04 Cobra PowerSlot Rotors $50 for BOTH!
- Just turned. One at the limit, the other could be turned again. These sell for $130 each new.
99+ Mustang Cobra Front Stainless Braided Brake Lines $25
- These are used. Right side line is in very good condition, left side as an abrasion in the SS braide near the middle from rubbing. These won't fit my 94, I never installed them. Sold as-is.
94 GT 17" Tri-Bar Wheels \w Toyo Proxies $250 firm
Stock gray/silver 94-95 17" GT wheels with 245/45/17 Toyo Proxies. Very good shape, only a few very minor scrapes. Front tires have 4/32 to 6/32 and a little feathering on the edges, but still good. The rears are evenly warn and have 5/32 to 6/32. Comes with center caps.
ZEX DRY Nitrous Management Unit (Brain) $120
- Including 24" AN3 hose & nozzle, plus NEW jets for 75/100/125.
- Use but looks to be in good condition but I have never used it.
I found out that Nitrous in GA is for track use only. Just having it hooked up in the street can get you a ticket, so I'm selling all my stuff.
ZEX 10lb Nitrous bottle \w nipple and 12" hose and brackets $110
- Almost new, 1.5" scrape on the side near the bottom.
Auto Meter Nitrous pressure guage $20
- Used but looks to be in good gondition. Does NOT include pressure sensor.
I never used it as I explain above.
** Combo of all the above Nitrous stuff: Bottle, ZEX box, and guage $200
ZEX 7.5" Cam Degree Wheel NEW in box $15
Poweraid Throttle Body Spacer #400-524 for 03/04 Ford Mustang GT 4.6L $40
Just the Spacer! Used, NO bolts, gaskets, or brackets.
http://www.sfxperformance.com/parts/ARD400524.htm
Pro-M/Best Products Remote Optimizer 1996+ (oval/rect 6 pin, 4 wire) $115
- Will not fit 1995 or older wiring. Will fit the MAFs I'm selling. The MAF with the pig tail can be used to adapt to other years.
http://chainlightning.net/images/RemoteOpt.JPG
Explorer/Mountaineer GT40 Upper (external EGR) $75
- Minor scuffs on the top & small ***** in ribbing.
http://chainlightning.net/images/intake1.jpg
http://chainlightning.net/images/intake2.jpg
http://chainlightning.net/images/intake3.jpg
http://chainlightning.net/images/intakebtm.jpg
Stock 1998 5.0L crank $30
- Slight grove on rear seal journal all rod & mains are clean.
Just do a very light polish (optional) and ready to go!
http://chainlightning.net/images/crank1.JPG
http://chainlightning.net/images/crank2.JPG
Stock 1998 5.0L Rods & Pistons (hyper) $30
- Skits measure right at 4.00", dirty but in good shape.
** Combo Full rotating assembly listed above $50
Yellow 19# Injectors (skinny style) with square plugs $35
- All are between 14.0 and 14.2 ohms within specs (14.0-14.5)
http://chainlightning.net/images/inj19a.jpg
http://chainlightning.net/images/inj19b.jpg
98 Explorer/Mountaineer Oil Pan $20
- Small dent in one corner, easy to bag out.
http://chainlightning.net/images/oilpan.jpg
98 Explorer/Mountaineer Valve Covers $20
- Good condition
Ford 85mm MAF (metal) \w sensor (oval 6 pin) $25
http://chainlightning.net/images/MAF3.JPG
http://chainlightning.net/images/MAF4.JPG
Ford 85mm MAF (metal) without sensor $8
50oz Pro-Products PowerForce Damper Weight (NEW) $8
(JUST THE WEIGHT!) I'm going 28oz so I don't need the 50oz weight
svc1@chainlightning.net
PM me if you want to talk on the phone.
I take credit cards via PayPal if you want to pay the 4% fee.
94 Vert - Bone stock, but not for long!
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Engine running like crap...pulled codes. 89stangalang 5.0 Tech 6 09-14-05 11:25 AM
