Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Reload this Page Some Basic TwEECer Tips
Notices
Reply
(#1 (permalink))
Old
vristang's Avatar
Official Member
Some Basic TwEECer Tips - 06-03-06, 10:16 PM
Here is some stuff not really addressed in the TwEECer manual, as downloaded from http://www.tweecer.com/downloads.htm
1. The "Update Only" checkbox has a bug that will randomly corrupt the tune when it is loaded into the tweecer. Always double check that this box is not selected after making modifications, as it seems to be check by default. The checkbox shows at the bottom of each of the tabs.
2. When datalogging make sure that you have created a payload and saved the tune (.ccf file) with the "Data Logging" checkbox selected. If this is not done then CalCon will not show any activity while the engine is running.
3. Do not remove the file "Logfile" from the folder "LogFiles". This file is a format file that is used each time a datalog is created. Without the file in this location, datalogging is not possible.
I hope others can add to this.
Welcome to the Fox 5.0 Tuning discussion.
jason
Last edited by vristang; 01-29-08 at 12:14 PM. Reason: Items 4 & 5 were incorrect, so they have been removed.
(#2 (permalink))
Old
vristang's Avatar
Official Member
Basic First Changes - 06-03-06, 10:39 PM
Here is a summary of some of the first changes that need to be made when starting out with the TwEECer. After performing these changes it would be a good idea to do some data logging and verify that KAMRF 1 & 2 are not too far off from 1.00. The EEC-IV seems to have a maximum adaptive ability of 12%. If you are getting readings of 1.12 or .88, then you have maxed out the ability of the computer to make changes with the KAMRFs.
Hardware/Hard Tune Changes
1. Set Base Timing to 10*
__a. Timing adjustments will now be made with the tuner
2. Set Fuel psi to 38-39, or install stock regulator
3. Set Base Idle (make contact with idle screw, then turn 1/2 turn more)
__a. Idle adjustments will now be made using the tuner
4. Ensure TPS is between .6v to 1.1v.
__a. Anywhere in this range is acceptable
TwEECer Changes
1.Turn off EGR function (If system has been removed)
2. Disable Thermactor Control (If system has been removed)
3. Set idle
4. Change MAF Transfer (download if available)
5. Change Injector High/Low Slopes per TwEECer Manual.
6. Change CID scalar
8. Change Adaptive Update Rate values to either 3or 10. All values except the bottom 2 rows can be changed (you don’t want to change closed throttle positions as it will cause problems on decel).
Last edited by vristang; 01-29-08 at 12:45 AM. Reason: Corrected some Errors & Added Clarifications
(#3 (permalink))
Old
strtrcr50's Avatar
Official Member
12-06-07, 10:19 PM
And get BinEditor and EECAnalyzer
88 Mustang LX 5.0 Convertible. Custom front and rear bumper mods and custom frame work courtesy of a Kia Sportage.
Quote:
Originally Posted by RS200 View Post
Honda-Tech is more of a forum than 5.0 Talk ever will be...at least there are signs of intelligent life there.
PSN Id-Slo5oh
(#4 (permalink))
Old
Official Member
01-16-08, 01:08 PM
I've read this before...
that I will need Binary Editor and EEC analyzer software licenses: (est $110) when purchasing a Tweecer RT.
I've also read that I'll need to replace these need O2 sensors with wideband sensors in order to dynamically read A/F ratio.
Where can this software be purchased and is there a preference of Vendor (Bosch, etc) for the sensors ?
(#5 (permalink))
Old
Official Member
01-28-08, 11:41 PM
Where can this software be purchased ?
Yes, I would very much like to know that.
I may be able to purchase a good used RT so would
definitely need to know a source for the software licenses.
Thanks!
89 Linc Mk VII LSC mass air w/A9P; 95 351 Lightning shortblock, 1.9 Ebrock heads, GT40-351 lower w/match Explorer top, 70mm mass air w/30 lb inj's, TF Stage 1 w/1.72 Crane rockers, 1-5/8 ceramic shorties, 2-1/2" Dynomax catback, 3 row rad, Ford blue hoses & wires, remote trans filter & plate cooler, 2500 lockup stall, beefed AOD, shift kit, 3:55's, 96 Cobra 17x8's, 99 Stang bolt on scoop. 4R70W, 2600 stall, Baumann TCS coming.
(#6 (permalink))
Old
vristang's Avatar
Official Member
01-29-08, 12:37 AM
When you purchase a tweecer or tweecer RT, you are only buying the HARDWARE.
The software supplied with the tweecer is free to download from the tweecer site...
The 'editor' on the tweecer site is called CalEdit.
The datalogger on the tweecer site is called CalCon.
Both of these software programs had several glitches, and it was starting to look like they would never be fixed. They didn't make the software unusable... just tougher to work with.
This is where BinEditor comes in.
BinEditor is a single program that incorporates both the editor and the datalogger.
EECAnalyzer (aka EA), is a separate program that is used to analyze datalogs and make reasonable suggestions for tune changes.
The creator of BE/EA is a fellow Mustang enthusiast who is pretty active in the continued development of the software.
More info can be found here...
http://eecanalyzer.net/
Both can be purchased here...
http://eecanalyzer.net/downloads/
EDIT:
I have edited the first 2 posts in this thread, as they contained some glaring errors...
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
TwEECer Tuning Manual BlueOvalStangGT 94-95 5.0 Tuning 17 10-14-07 04:40 PM
help me decide... tweecer R/T, PMS, or DFI? 1105 94-95 Tech 21 07-13-06 06:02 PM
Pointers, tips, links for Nacho on Tweecer R/T? He called me but I am no help. Thx! Pokageek 94-95 Tech 5 05-31-06 08:44 AM
Basic Spark Info For Tweecer Noobs & ??? final5-0 94-95 Tech 3 10-17-05 09:08 PM
94/95 PCM & Tweecer Basic Info Great Stuff if you want to learn! final5-0 94-95 Tech 8 11-05-04 12:35 PM
