Go Back   Mustang Forums at StangNet > Regional Forums > Southwest > SW Classifieds
Reload this Page Custom 86 Conquest with 5.0
Reply
(#1 (permalink))
Old
Official Member
Custom 86 Conquest with 5.0 - 07-06-06, 07:56 AM
Car is located in Pearland Texas.
13K
Before I get asked: I'm selling the car because I have too many. 4 cars are taking up a lot of room.
I had this car delivered to my house in January. I haven't even registered it yet. It has 150 miles on a brand new engine from Ford and new factory instrument cluster.
It has a crate 93 Mustang EFI 5.0 @ around 400 horse power in it.
It has an EC303 cam, roller rockers, trick flow intakes (upper and lower), flepro gaskets, double roller timing chain bigger injectors, fuel pressure regulator, steel braided fuel line. Basically it was set up for a Novi 2000 which I was going to add later. It even has a 190lph fuel pump.
It also has a tremec T-5 with king cobra clutch and ceramic coated headers. I don't know what it runs because of the new motor not being broken in yet. It also has a hurst shorty shifter and a custom aluminum drive shaft.
New silver paint job and tires.
ABS has been eliminated, it has a custom 4 core radiator (yes that's correct 4 core), a 15in push fan, and dual 10in puller fans set up on manual switches.
The wiring harnesses are completey seperate from each other. All the Mistu sensors and wiring are in the original locations. The only Mistu wire that is hooked to the Mustang computer is for the fuel pump pick up.
The Mustang computer is located in the stock Mitsu location.
It has 89 seat belts in the rear, an 89 HVAC control system, 89 LSD and half shafts, custom wheels (18X10 rear and 17X9 front) and custom ground control coil overs.
It has a new exhaust and highflow cat on it. The half shaft in the back was hitting the exhaust that was on it (which was also brand new). I have every receipt for everything that was bought and done to the car.
It has a kenwood deck, infinity amp, and rockford fosgate speakers. The interior has dyno matt sound deadning gel through out and new black mercedes carpet.
All the black leather seats are in great shape.
The A/C blows but is not cold (needs charging). The passenger seat belt does not lock when inserted (needs new latch). It has a momo steering wheel adpater.
It runs strong and drives as it sits. I drive it daily down the road just to keep the battery charged. The car is fast.
There is about 27 grand invested in this car.
It has NO RUST. You can come see the car for yourself.
Thanks for looking.
Email: ToneyCTDS@gmail.com
Phone: 713-504-8566 anytime.
The pics of the back hatch area is where I have removed the paneling to install the new factory antenna (which is not installed and I have a brand new factory antenna in the box)
Toney C
World traveler
Kellogg Brown and Root
(Halliburton)
(#2 (permalink))
Old
Official Member
07-23-06, 05:05 AM
No one is interested in this beautiful car??
I figured a pumped 5.0 in a Conquest would spark some sort of interest.
Hmmmm
Toney C
World traveler
(Halliburton)
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Custom cams ... ill advised 5.0 Tech 12 07-11-05 06:56 PM
New custom setup pics HighPsi91 2.3L (N/A & Turbo) Tech 1 05-17-05 08:25 PM
4.6 vs 5.0 tjm73 4.6 Tech 38 07-08-04 11:37 PM
'90 LX 5.0 vs '94 GT 5.0 Jeffyh 5.0 Tech 13 05-27-04 11:10 PM
custom tune today, very interesting !!! Dr. Wu 2000 4.6 Tech 8 04-03-04 02:27 PM
