Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Reload this Page Any way to lower idle without a tuner?
Reply
(#1 (permalink))
Old
Any way to lower idle without a tuner? - 08-16-06, 08:18 PM
My 89 has a b-cam and 1.7 rr that i installed over the winter with crane valve springs. The springs were tired after 180k miles so i put the cam and rockers in at the same time since i got a good deal on them. Anyway, i'm having problems getting the idle where i want it. I have the idle screw almost totally closed with the tp set at .98v. and i still cant get it any lower than abo9ut 1000rpms. i had the timing at 10* and it was at about 800 which i could live with. recently i bumped base tioming to 18* (no detonation) and obviously that raised the idle. is there any way, without a pms or tweecer, to lower my idle back to about where it was? I heard somthing about a plate that goes betyween the tb and iac but cant remember what the guy said. thanks. ooo and if you could spare me the flames about a cam in a stock motor i would apprieciate it cause ive heard enough lol thanks again.
'89 Mustang LX 5.0 196,000 miles(sniff) Best of 13.5 @ 99mph @Lebanon Valley Dragway
'84 F350 Reg Cab 460BB Tow Rig
'90 Plymouth Laser Daily Driver
'88 Mustang LX 4cyl T5 *SOLD*
(#2 (permalink))
Old
jrichker's Avatar
StangNet's favorite TOOL
08-17-06, 06:15 PM
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
http://bellsouthpwp.net/l/r/lrichker/index.htm
See my website for:
R134a conversion doc
Door lock actuator fix
89 Mustang GT totaled by a low life hit and run driver March 23, 2008. Sent to the boneyard for parts/recycling...
New ride - 89 LX 5.0 with a 5 speed, stock except for Cervini Stalker hood.
"Before you build a house build a good foundation"
(#3 (permalink))
Old
Official Member
12-04-06, 12:13 PM
If you have the idle screw backed all the way out, and the idle air controller unplugged and your idle is still at 1000rpm i'd check the vacuum. A leak would let more air in like an open idle air controller would... causing idle to go up.
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
IAC restrictor plate installed! R.J. 94-95 5.0 Tuning 138 06-21-08 08:20 PM
Turbo Idle Problem KenneBell 2.3L (N/A & Turbo) Tech 12 12-15-07 11:02 PM
so can the hot summer cause a lower idle?? Foxfan88 5.0 Tech 2 07-01-05 03:28 PM
I fixed my stuck idle freakazoid 5.0 Tech 1 06-27-04 02:28 PM
